Trs won't come off - Taurus Car Club of America : Ford Taurus Forum
Old 12-05-2012, 05:41 PM   #1 (permalink)
Member Number: 51529
Drives: 2000 ford Taurus
Justintime25 is an unknown quantity at this point
Default Trs won't come off
Ok so I'm in the process of replacing my transmission range sensor, I've diss connected the 2 bolts that hold the trs to the transmission, and also the nut that goes on that axle that passes through the trs. I then removed the shift linkage and now it's not attached to anything, yet it will not come off, supposedly it just pulls right off easily. It literally won't come off, any suggestions on what to do?
Justintime25 is offline   Reply With Quote Quick reply to this message
Old 12-05-2012, 05:45 PM   #2 (permalink)
intimidator's Avatar
Member Number: 18727
Drives: 12 SEL 201a 3.5
intimidator will become famous soon enough
Crud has it glued to the housing, try a plastic putty knife to break the "seal" loose
04 Taurus SES 3.0 Vulcan (gone)
03 Sable LS 3.0 Duratec (traded)
98 Contour Sport 2.5 Duratec (3 blown trannies racing)
97 Lincoln Continental 4.6 Intech (sold)
70 Yamaha Twin 250
00 F-250 SuperDuty 4x4 6.8 v-10 Triton( K.I.A. )
12 Taurus SEL 3.5 Duratec FWD
06 Magnum R/T 5.7 Hemi AWD
intimidator is offline   Reply With Quote Quick reply to this message
Old 12-05-2012, 05:54 PM   #3 (permalink)
Ok, I don't quite understand you though. Are you saying to Basiclly clean it and pry it up? There's not to much to move around though. I didnt want to pull on it too hard, didnt want to break it.. Is it usually hard to remove it off of the shaft?
Old 12-05-2012, 05:59 PM   #4 (permalink)
A little penetrating oil around the shaft area,and around the outside of the housing ,use a plastic putty knife to pry,as to not gouge any surrounding areas
It'll come off, I had to replace one on my truck after 195k on the motor, took about 10 minutes to get the friggin thing to move.
70 Yamaha Twin 250
Old 12-05-2012, 06:42 PM   #5 (permalink)
Ok thanks for your info. When you say spray around the housing do you mean the transmission housing? And I'll spray some liquid wrench on it and pry away.
Old 12-05-2012, 07:51 PM   #6 (permalink)
Yes, around the trans housing where the trs meets....this area of the engine compartment gets a ton of debris,combined with moisture,heat and time, it makes for a nice adhesive.
70 Yamaha Twin 250
Old 12-06-2012, 11:19 AM   #7 (permalink)
Ok so now the range sensor is loose from the transmission housing, i can move it around but it still won't come off of the axle. I've tried prying it and everything. I don't want to break the axle so I haven't pulled too too hard on it. Do you recommend yanking it really hard? Or maybe I should try and pry it harder?
Old 12-06-2012, 12:01 PM   #8 (permalink)
Member Number: 11378
Jeff K has a reputation beyond reputeJeff K has a reputation beyond reputeJeff K has a reputation beyond reputeJeff K has a reputation beyond repute
Maybe you can get a small gear puller on it and remove it that way.
02 Pontiac Grand Prix GT
Jeff K is online now   Reply With Quote Quick reply to this message
Old 12-06-2012, 02:42 PM   #9 (permalink)
Ok I have a small gear puller I'll try to use after work and I'll report back with the results. One more question, can the axle shaft take a lot of stress? Cause I need to pull on the trs reallllllyyyyy hard to remove it.
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
