Member Number: 13548
Drives: 99 SHO welded
A couple months ago I noticed a rust bubble between the back door and whel well so I got the grinder out this weekend and before I knew it I had the rocker trim off and I was staring at a bunch of rust under the back door. Front door actually looks pretty good.
I ground off most of the crap metal, sprayed some rust converter on it, and a couple coats of primer to get me by for a while. Took it by the body shop today and he said $300 to weld in the replacement rockers (supplied by me - they're pretty cheap, $25 per side) and paint it. Sounds like a fair deal, but as usual - now I'm thinking I should just tackle it myself. Given the location - appearance is so unimportant it seems like something that would be pretty hard to mess up bad enough for it to matter. I think one of the hardest steps to get right would be locating the holes correctly to allow the trim to snap back in place. My main objective would be to clean it well enough, and protect it well enough to keep it from rusting at least for the next 3-4 yrs. He described the prep process to me and as I understand it he basically expects me to have it prepped before I take it back to him. He explained where to cut the bad panel so it could be replaced and welded with a new piece. I have done some basic welding before, but I would have to acquire a welder. I might be able to access one at work for a few hrs. What about coatings before/during installation? It seems like it would be wise to coat the new panel before welding it in place, but I don't expect any coatings around the weld area to fare well. |
Member Number: 26577
Rep Power: 5 ![]() |
There are weld thru coatings. I don't use them. I spray the inside of the rocker with Eastwood Heavy Duty Rust Preventer after welding, and call it a day. Should outlast the rest of the car.
Jeep Rust Repairs Finished, and after rust proofing: ![]()
Thanks eg. The welder (and weldING) will probably be my big obstacle. I have a couple possibilities in the works though.
I've been searching around for some internal rust inhibitor sprays. Seems like a good idea. I think I can open it up a little more w/o any real effect on having enough material left to attach to. It seems to me I need to make a better effort to clean (probably wire brush on the grinder) some more loose rust out of there. What about a good filler? I have a half-dollar sized hole on the little strip of metal between the door and wheel well that I will need to try to fill. |
#4 (permalink) | |
Cake monster
Member Number: 18214
Drives: none right now
After you get the rust issues sorted, get the car undercoated with an oil coating. It's very popular in Canada and it works very well. They will fill the rockers and interior panels as well. One popular company that does this is "Krown Rust Control".
#5 (permalink) | |
Cake monster
By the looks of it, you did a great job in the photos!
I love cake. I AM THE CAKE BOSS! Last edited by JW657; 12-05-2012 at 03:46 PM. Reason: grammars and such |
