Rep Power: 21 ![]() |
What's the most common cause for a non-working tach? Tach itself, faulty crankshaft position sensor (ckp) or something else? 99tec is running fine, but tach sits at 0. If you tap the cluster lens with your fingers or knuckles, needle will bounce up midway or so and work correctly for a few moments, then settle back down to 0.
![]() Member Number: 49890
My guess is on the tach itself. Could just be loose wiring in the dash. If you can tap it I doubt it's an issue besides the tach itself. Just pull apart the cluster and reseat the tach in the cluster. PITA, but may fix it. If you have an extra tach around throw it in there... I've got one if you need it, give it to you free plus shipping (just the tach).
I feel like if it was a problem with the actual tach lead on the motor that it would be throwing a code since the PCM wouldn't be getting the correct data for engine speed, right?
Taking Care of Business
Member Number: 40467
Drives: 2004 SEL Duratec
No, the engine sends the speed to the tach. Wouldn't throw a code.
Member Number: 1771
Is the car in question a floor shift model? Do you have another floor shift model in the household?
I would do a quick swap of the cluster and see if the tach works with a different cluster. Isolate if wiring is the issue or the cluster. E-z to do on Gen 3 floor shifts. Pop out bezel, then remove 4 screws for IC...out comes the cluster.
#5 (permalink) | |
I can't find the dang diagram again. If you guys say it doesn't go to the PCM before the cluster I'll believe you! Nick, I love how you say "E-Z" instead of "easy". It's just always made me chuckle.
Member Number: 11378
Rep Power: 14 ![]() |
IF the engine runs, it isnt a CKP problem, as tach gets its signal from CKP. G4 (at least later G4s) get this signal via the PCM as Sam said, but I am not 100% sure if the G3 is the same.
Could be as simple as a loose / corroded connector to the cluster. Happened a few years ago on my 88 Turbo Coupe (electronically driven speedo & odometer). Speedo / odometer quit one day. Pulled cluster and cleaned cluster connectors / contacts. Put it back together. Has worked fine ever since.
Member Number: 43818
Drives: 2010 Taurus SHO
Rep Power: 2 ![]() |
As long as were on this subject, we have a similar problem in our 99 Sable. The tach may or may not operate...sometimes it seems to work fine, then other times it will show really high revs, or will show rpms as the car goes through shifting gears and as it upshifts to 3rd, the tach will die and show no rpms. Car runs fine just the tach is very "iffy" about working....any suggestions?
2010 Ford Taurus SHO-Livernois 4+ Tune, Airaid CAI, Caliper Covers, Tinted Taillights, Tinted Headlights, LED Interior Lighting, LED Puddle Lamps and License Lights, SHO Hood Stripes, Rearranged Trunk Badging 2004 Ford Explorer Limited-Wife's Tow Vehicle 1999 Mercury Sable LS-Our "Beatermobile" |
#8 (permalink) | |
#9 (permalink) | |
#10 (permalink) |
Mjhpadi, maybe our 99tecs' tachs are cursed, like their vss'. I'll pull the cluster tomorrow and check/clean connections, etc. If that fails, may grab a tach or entire cluster from the self service salvage yard.
