Member Number: 19053
Drives: 2002 Taurus
Vulcan 3.0
158,000 miles
My 2001 Taurus was not being used so 3 weeks ago I pulled the battery to use in another car. Today I bought a new battery, put it in. .. Taurus will not start. I get lights they don't dim when I turn the key so I assume the battery is good. I get the clicking starter, I DON"T get the cranking noise .. only the clicking. It is not the fuel cut-off switch, checked that. The starter and alternator are only about a year old... and yes there is gas in the car. Again the car had not been run for 3 weeks or more here in the cold
![]() ![]() Northeast. I'm totally baffled.
Member Number: 33178
Drives: 1994 TAURUS LX WAGON 3.8L V6
Rep Power: 3 ![]() |
Sounds like battery, have it tested whereever you got it, im sure they will give you a new one.
Sounds like you have a cable or terminal loose. Make sure the positive starter cable is attached securely at both ends. It might also be the starter. Try giving it a few taps with a wrench or small hammer (don't go crazy and dent it or anything).
Member Number: 5295
Drives: 2005 Taurus SE
3.0L Vulcan
Rep Power: 16 ![]() |
^^^^Agreed.
#5 (permalink) | |
Member Number: 3136
Drives: 1998 LX black Vulcan
1997 SE black Vulcan
Rep Power: 11 ![]() |
Member Number: 20381
Drives: 96 Mercury Sable LS Wagon
3.0 DOHC Duratec
Rep Power: 5 ![]() |
1. Double check the connections and make sure they are tight and clean.
2. Check bat voltage if you have a volt meter. Should be 12.4 or higher but slightly lower should start the car. If the battery was sitting around in store for a while it may need a charge or like someone else mentioned it may be defective. 3. Starter (or relay) may be bad. If it easily jump starts the starter will be ruled out and possibly the connections. I would bet 1 or 2 because that is what changed. |
Member Number: 35029
If the inside lights don't dim when you turn the key to the starter position, and you hear a 'click', then most likely is the starter. The main cable for the starter is a thick one that connects to the battery positive pole - is that connection is good and solid, then the starter needs to be replaced.
