99 Taurus power steering pulley remove/install - Page 2 - Taurus Car Club of America : Ford Taurus Forum
post #11 of 16 (permalink) Old 11-25-2012, 03:47 AM
wjc
wjc's Avatar
U = Vulcan non-dohc.
wjc is offline
post #12 of 16 (permalink) Old 11-25-2012, 03:23 PM Thread Starter
You probably already know this, but don't run the engine more than a minute or two with the belt off due to the risk of overheating since the water pump isn't turning. Just wanted make sure.
Yeah that's exactly what I did, I ran it for about 30 seconds to make sure that the main spinning pulley wasn't the problem, thankfully it wasn't.
Mikedh990 is offline
post #13 of 16 (permalink) Old 11-25-2012, 03:24 PM Thread Starter
Non-dohc? I'm not familiar with the term.
post #14 of 16 (permalink) Old 11-25-2012, 04:47 PM
Cake monster
Ford had two 3.0 engines for the 3rd and 4th generation Taurus. One is an old school 12 OHV (Overhead Valve) push rod engine. The other is a modern 24 valve DOHC (Dual Overhead Camshaft) engine.
If you google "DOHC vs OHV" you will get a ton of explanations and comparisons between the two.
JW657 is offline
post #15 of 16 (permalink) Old 11-25-2012, 05:29 PM
Exalted Grand Poobah
Lgbpop's Avatar
Year: 1990
With the Vulcan, that noise on the front of the engine often is caused by the bearings going on the tensioner pulley and it's an easy, inexpensive replacement.
Lgbpop is offline
post #16 of 16 (permalink) Old 11-27-2012, 08:48 AM Thread Starter
The tentioner was actually the first thing I replaced myself. After spending about 3 hours on it, I cleaned and scrubbed every pulley and put a brand new belt on there. The noise stopped! Finds out that the stuff that's suppose help end the noise can actually cause it, and it didn't help that the guy from the used car lot was using electrical part cleaner on it before we bought it. After all that work the only sound is coming from the idler pulley. The barrings are the best but its something that can wait a couple paychecks
