#11 (permalink) | |
Did you replace the mega fuse with the cable? I would. |
#12 (permalink) |
Member Number: 7489
If the cable connection at the battery was loose and/or the cable itself was too small for the load, that could go before the fuse. The fuse is supposed to be the weakest link, but if something else presents itself Murphy's Law comes into play.
Now that you are all fixed up, I recommend replacing the mega fuse. Even if it didn't blow before the other stuff, it still took a beating electrically. |
#13 (permalink) |
Member Number: 51265
Drives: 1997 Mercury Sable DOHC Duratec
There were no obvious shorts by the megafuse, it's all pretty secure and covered in plastic.
I'll replace the fuse anyway, and have a closer look at the fuse box for possible shorts. Thanks for all the help guys. |
#14 (permalink) |
Member Number: 35029
Rep Power: 5 ![]() |
Don't worry about the megafuse. Your short happened at alternator side, no signifiant current flowed trough the megafuse...
#15 (permalink) |
Member Number: 7489
Something caused that cable to go, and it seems to me it would have gone straight from the alternator through the fuse to the cable.
#16 (permalink) |
Here's a small diagram of the link between the Battery and the Alternator.
One possibility is that I think the cable between the megafuse and the alternator, is thicker or lower guage, then the battery to megafuse. ![]() (The small thick black line is the megafuse) |
