Chime won't turn off when head lights are on, interior lights stuck too... - Taurus Car Club of America : Ford Taurus Forum
Old 11-17-2012, 04:13 AM   #1 (permalink)
Member Number: 45334
Drives: 1993 Ford Taurus 3.8 (sedan, Black) 1994 Ford Taurus 3.0 [sedan, Green)
One to Remember is an unknown quantity at this point
Default Chime won't turn off when head lights are on, interior lights stuck too...
I have a 1993 Ford Taurus LX 3.8 litter. I can not get the interior lights to stay off, and that chime that sounds when a door is left over would not turn off for awhile. I know that the ignition cylinder had something to do with that so i went ahead and just removed the clip fully from the ignition well. That stopped it when I was driving but the door, above, and glove compartment lights still would not turn off. Now I have an issue were I can't turn my head lights on without the chime coming on.
I don't think i won't to disable the chime ding out right JUST YET, I would still like to remedy its malfunction but if not i will go ahead and take the "bell" out where ever it is..
I am pretty sure my door buttons that get pushed in when I shut them are not the issue for the chime or the light situation nor is the dimmer. What can I do short of taking out more lights? I do not want to have no light underneath the glove compartment or own the doors when i open them..
I know this isn't an original topic but none of the other threads seemed to help.
One to Remember is offline   Reply With Quote
Old 11-17-2012, 05:54 AM   #2 (permalink)
Member Number: 17094
Drives: 1999 Taurus SE Duratec
Scout1 has a little shameless behaviour in the past
Sounds like a bad door switch or a broken wire coming from it. Most likely in the harness in the hinge area. You will have to get a wiring diagram and trace it out. It could be any door but I would suspect the drivers since it gets the most use.
Ed
Scout1 is offline   Reply With Quote
Old 11-17-2012, 06:58 AM   #3 (permalink)
Ed
ill look into that later today but do u think that will fix the chime AND the light issue or just 1?
Old 11-17-2012, 07:53 AM   #4 (permalink)
I looked at the wiring diagram at the Autozone website. I now think you have a bad switch that is making contact (closed) all the time and not a bad wire. Though you may have a shorted wire. Try spraying your door mechanism heavily with WD40 and work it a few times. If that doesn't work you are going to have to check the circuit with a meter to see what is going on. I did not see the chime circuit but if you have a stuck switch or bad wire I am sure it would cause the chime also. I am sure someone else with have a little better info. Just trying to help.
Ed
Old 11-17-2012, 06:35 PM   #5 (permalink)
Yes, fixing the door latch should correct both issues.
Old 12-01-2012, 05:58 PM   #6 (permalink)
Ed
do i need to check the back doors too? and if i am not able to get it to work what else would me snipping the wire for the chime cause to not work? And I should spray the WD40 in side of the little box holding the wires?
Old 12-01-2012, 09:12 PM   #7 (permalink)
The chime will only be activated if the driver's door is sensed to be open, so I would say your problem lies with the driver's door switch. It's possible you have another bad switch, but focus on the driver's door first.
Spray the plunger that gets pushed in and out when the door closes and push it in and out a bunch of times with your finger. If you still have problems, you might have to replace the switch. Also inspect the wiring going to it for any damage.
Old 12-01-2012, 10:02 PM   #8 (permalink)
Breeves002's Avatar
Member Number: 49890
Push the plunger in after spraying and see if the dinging stops when you do (with the lights on or motor running).
If not could be the switch or wires are bad.
2012 Kia Soul Base AT 1.6GDI
CLICK HERE
