Member Number: 51189
Drives: 1995 Ford Taurus SHO 3.0L
Hi, I'm new to the SHO scene but have worked on vehicles for years. I have a 1995 Ford Taurus SHO 3.0L MTX. I can't seem to keep the car running. I have bought a new alternator and battery as well as idler pulley. The car will still not charge anything. I took the alternator out got it tested it read 17.5 volts. Just to make sure i had it exchanged. Got the new part and still no luck. I've tested all my leads and everything seems to be working fine. What could the problem possibly be? No fuses are blown no major draws no shorts.. I'm totally stumped. Any help would be appreciated.
![]() Member Number: 49890
Check grounds and cables.
I've done that as well. Still no good. Everything is pulling the correct ground. Voltmeter.
So let me make sure: the car will start up and run until the battery dies, correct? Or will it run but not charge the battery.
Yes you are correct.. It will start when the battery is charged run for about 15 minutes then dies.. no battery light comes on.
Member Number: 18727
Drives: 12 SEL 201a
3.5
Rep Power: 5 ![]() |
Can't remember....internal or external voltage regulator? Could be the culprit if the grounds are good and no draw detected.
04 Taurus SES 3.0 Vulcan 03 Sable LS 3.0 Duratec 98 Contour Sport 2.5 Duratec 97 Lincoln Continental 4.6 Intech 70 Yamaha Twin 250 02 Kawasaki Vulcan Custom Twin 800 00 F-250 SuperDuty 4x4 6.8 v-10 Triton 12 Taurus SEL 3.5 Duratec FWD |
no external regulator, no fuseable link. Computer issues maybe? throws no codes..
Check the fuse I indicated in your other post.
P.S. Please don't double post for the same issue. |
#9 (permalink) |
Checked all fuses are fine.. And i apologize with posting on both sections. I have read the link wrong and unaware on how to delete at this time lol.
#10 (permalink) |
Okay, then you need to check the voltages on the back of the alternator to make sure the connections and wires are good.
You should have +12V on the large yellow wire and the orange/light blue wire at all times. With the key on you should also have +12V on the light green/red wire from the instrument cluster. If you don't have voltage on the yellow or orange wires the mega fuse might be blown. There is a field test screw on the back of the alternator for testing, but you have to be very careful using it. When you ground the screw, it will send full current through the field coil, and the alternator should produce maximum output. However, the voltage will not be regulated, so the high voltage can damage other components. Therefore, you must have the screw grounded for only a very short time, like one or two seconds. Obviously have your volt meter set up and ready well before you do this. |
