HELP No Charge! - Page 2 - Taurus Car Club of America : Ford Taurus Forum
Old 11-13-2012, 10:36 PM   #11 (permalink)
Member Number: 4817
Drives: 1992 Taurus SHO
Cool
Have you cleaned the battery cables?
92 White SHO
http://www.shosource.com
Old 11-16-2012, 04:37 PM   #12 (permalink)
Member Number: 51189
Drives: 1995 Ford Taurus SHO 3.0L
cuzimmaG is an unknown quantity at this point
Default Still no charge
Update! Ive checked everything you guys have told me too. Here is what ive done so far. New Alternator twice, Battery, Changed my fusible links in the wires, The idler pulley is new, new belt, and STILL NO CHARGE : ( Where is said mega fuse located? I'm so lost now I'm not sure what to do, Ive been chasing this problem for 2 weeks now with no prevail... Please help car is 1995 Taurus SHO 3.0L MTX DOHC
cuzimmaG is offline   Reply With Quote
Old 11-16-2012, 05:10 PM   #13 (permalink)
Sorry, you have fusible links instead of a mega fuse.
With the key off, on the back of the alternator make sure you have +12V on the black/orange wire and on the yellow/white wire. Report what you find.
Old 11-16-2012, 06:05 PM   #14 (permalink)
Default yikes
I will check the voltage in the morning but i literally just changed that 18g brown link on that wire.
Old 11-16-2012, 06:40 PM   #15 (permalink)
Member Number: 4817
Cool
Did you clean the terminals? Bad terminals can cause problems.
No there are some mega fuses on the driver side firewall.
92 White SHO
Old 11-16-2012, 07:20 PM   #16 (permalink)
I changed the battery terminals so they are new as well... mega fuses on the firewall are all fine.
Old 11-17-2012, 04:32 AM   #17 (permalink)
Member Number: 45334
Drives: 1993 Ford Taurus 3.8 (sedan, Black) 1994 Ford Taurus 3.0 [sedan, Green)
One to Remember is an unknown quantity at this point
so after the 15 minutes of being on does everything start to dim around 14 minutes? is the battery dead completely after ur car shuts down? a juiced up batt even without an alt should go for like 4 to 6 hours..
One to Remember is offline   Reply With Quote
Old 11-17-2012, 10:43 AM   #18 (permalink)
yes after 15 minutes of the car running i watch the digital clock dim down then everything else goes with it. The car will not turn back over after it dies, battery says 11.79volts. The orange and black wire on the ALT reads the same as the battery when the car is off.
Old 11-17-2012, 02:21 PM   #19 (permalink)
its not the battery then and i doubt a misbehaving alt is going to cause ur still 90 percent juiced battery to deprive the vehicle of energy. u might wanna disconnect the alt outright just to see if you can run off of pure battery. after that id focus on things that regulate and distribute the flow of power thru ur car..
Old 11-17-2012, 06:45 PM   #20 (permalink)
What about the yellow/white wire?
