Member Number: 51107
Drives: 1996 Ford Tarus GL wagon 3.0 liter V6 engine gas not flex
Over the last 3 years I have attempted to find and fix the problem with the EGR. The check engine light is always on, had computer check for trouble codes. MAF and EGR Valve were bad. I have replaced EGR Valve and the Vacuum Solenoid. The car was losing power and using more gas. I replaced the MAF, that fixed it for a week. Then put on the EGR Valve and drove from VA to MI with out problem, then some thing just didn't feel right so I had computer check and just said EGR again over and over. Car seems to run rather rough, always sounds rather loud. Advice?
![]() Member Number: 49890
Did you replace the DPFE sensor? The EGR valve rarely goes bad, and the EVR even less often. Do you have lean codes (P0171 and/or P0174)? You could have a vacuum leak.
Rep Power: 21 ![]() |
^+1 with Sam. Probably need to replace the dpfe (egr pressure sensor). Is the code po401 (p1401) or po402? Which engine does your '96 have? 3.0 12v ohv Vulcan or 3.0 24v dohc Duratec? Being a GL, I'm guessing Vulcan?
The Backpressure sensor (DPFE sensor) no not yet.
What are the codes that are on there now?
I had it check at Jiffy after oil change a day ago and they didn't add the codes # just the name of the code (EGR VALVE). I going to take her in a Ford shop to get a better check later this week.
Go to autozone or somewhere like that and they will read your codes for free. There is no code that is named "EGR VALVE"... There is no way for the computer to know if the EGR valve is bad without adding a bunch of expensive sensors. So the DPFE instead monitors the EGR flow and will set a code if it sees a variation in what the flow should be. The DPFE unfortunately goes bad and will tell you there is a problem with the EGR valve when there is not.
If it is an EGR problem you will get something like P0401 or P0402. Make sure you write them down EXACTLY as P1401 and P0401 are VERY different.
^+1. Autozone or Advance Auto will read codes for free.
#9 (permalink) |
Just get the exact code number. Pay no attention to what the slip or the clerk tells you to replace. They have no idea what they're doing and would love to sell you EGR valves all day long.
#10 (permalink) |
Member Number: 33869
Rep Power: 4 ![]() |
You might also clean the throttle body where the channels go to EGR valve. Usually full of carbon and prevents operation due to lack of flow to EGR.
First thing I do before throwing parts at it! Also bad EGR gasket can cause issues!! Just some thoughts on the cheap~~ |
