Where to inject Seafoam on 99 DOHC Motor?? - Taurus Car Club of America : Ford Taurus Forum
Old 11-11-2012, 01:10 PM   #1 (permalink)
Member Number: 47138
Drives: 99 SE DOHC
cjinohio03 is an unknown quantity at this point
Question Where to inject Seafoam on 99 DOHC Motor??
Last time I tried using a vacuum hose that went to the duct before the throttle body. That didnt work too well at all. Where should I use instead? I didnt see a hose going directly to manifold etc. Thanks in advance CJ
cjinohio03 is offline   Reply With Quote
Old 11-11-2012, 03:55 PM   #2 (permalink)
98SilverSable's Avatar
Member Number: 41989
Drives: 1998 Mercury Sable LS Premium, 3.0L Duratec 24V V6
98SilverSable is an unknown quantity at this point
try this from the website:
Sea Foam | How to Use Sea Foam Motor Treatment
or if it's the Deep Creep, there's a section here on throttle / intake cleaning
http://www.seafoamsales.com/how-to-use-deep-creep.html
"If I had money, I'll tell you what I'd do.... I'd go downtown and buy a Mercury or 2, crazy about a Mercury. Yeah, I'm crazy about a Mercury. I'm gonna buy me a Mercury and cruise it up and down the road!"
- Alan Jackson - "Mercury Blues"
Facebook
98SilverSable is online now   Reply With Quote
Old 11-11-2012, 04:09 PM   #3 (permalink)
Member Number: 49924
Drives: 98 Taurus SE 3.0
TaurusSE98 is an unknown quantity at this point
Pull the hose off the brake booster. Should have strong vacuum coming from it to the intake manifold. Car might run rough because of the vacuum leak, but slowly dribble it in, do at least 1/3 can. I usually do 1/2. You may need someone to hold the gas at 1500rpm or so to keep it running, but the key is to apply it slowly. Then shut the car off for a while. Get ready for a smoke show when you fire it back up.
TaurusSE98 is offline   Reply With Quote
Old 11-11-2012, 09:35 PM   #4 (permalink)
Use as hose after the throttle body, like the booster hose. Remember to go slow so you don't stall the engine.
Old 11-11-2012, 10:19 PM   #5 (permalink)
caseitman's Avatar
Member Number: 24956
Drives: 1996 Ford Taurus SHO 3.4L V8
caseitman is an unknown quantity at this point
what does Seafoam do for an engine?
caseitman is offline   Reply With Quote
Old 11-11-2012, 11:24 PM   #6 (permalink)
The idea is that by introducing Sea foam (which is a mixture of solvents) through the intake, the liquid will be sucked down into the cylinders and clean the carbon deposits off the intake manifold, runners, and the backside of the intake valves. Clean valves and runners will improve performance, fuel economy, and engine smoothness. However, the method of introducing the liquid into a vacuum port is very crude, and will really only just run down into one or two cylinders and create a smoke show. Suffice to say, the pros never do it that way. The best way to do an induction cleaning is by using a mist that's introduced at the throttle body, so the atomized liquid can reach all cylinders equally.
All the smoke gives the psychological effect that all the carbon has been cleaned out of the engine. So in a way Sea foam is the ultimate automotive placebo product, and I think that's why it sells so well.
Personally, I only use Sea foam on carbureted engines, since the carb helps atomize the liquid properly and sends it equally to all cylinders.
Old 11-12-2012, 03:13 AM   #7 (permalink)
DN101's Avatar
Member Number: 35588
Drives: '98 Taurus SE, Duratec V6
DN101 is on a distinguished road
The best way to do an induction cleaning is by using a mist that's introduced at the throttle body...
Such as?
DN101 is offline   Reply With Quote
Old 11-12-2012, 08:52 AM   #8 (permalink)
Member Number: 33869
Spray of solvent in fine mist into Throttle Body or carburetor ..
I just run a can through my gas tank every month in Winter.
Done incorrectly you can really screw things up like O2 sensors and foul plugs!!
At $6-10 a can it gets kind of pricey for the benefit.
Old 11-12-2012, 11:02 AM   #9 (permalink)
Originally Posted by DN101 View Post
Such as?
Sea Foam Spray for one. 3M also makes a similar product. But the professional products (like BK) use an air-pressurised cylinder that's hooked up to a nozzle placed in front of the throttle plate to dispense the product.
Old 11-12-2012, 11:07 AM   #10 (permalink)
rm.
