Belt squeaking still! Question, ordered tensioner... - Taurus Car Club of America : Ford Taurus Forum
post #1 of 11 (permalink) Old 11-07-2012, 12:56 PM Thread Starter
With car running and belt squealing, if I spray wd40 on the tensioner pulley, the belt hops over a little bit and squealing stops. I'd imaging this means the tensioner pulley is out of alignment, but I don't see any way to adjust the alignment of any pulleys. I tried searching, but can't figure out how to align pulleys. I went ahead and ordered a Dorman automatic tensioner, so I'll be installing that soon...
TaurusSE98 is offline
post #2 of 11 (permalink) Old 11-07-2012, 02:56 PM
wjc
wjc's Avatar
There is no pulley alignment, look straight down at all the pulleys and you should be able to see which one is out of line. Hopefully you ordered the right part.
wjc is offline
post #3 of 11 (permalink) Old 11-07-2012, 04:01 PM Thread Starter
I ordered part no 419-201 from amazon... I already put fresh pulleys on tensioner and ilder (waste on the tensioner I guess...) and a fresh dayco belt, so after this it should be good to go. It looks like the tensioner pulley is skewed a lil bit, when I spray wd40 it hops over a bit and quiets down, but goes back closer to the edge as the wd40 dissipates and the squeaking comes back.
post #4 of 11 (permalink) Old 11-07-2012, 06:58 PM
Are you sure everything is tightened properly on the tensioner and idler?? Take off and clean behind it and check for proper install from previous Owner>?
Not much of a Dorman fan but this part should be ok for you!!
downhill is offline
post #5 of 11 (permalink) Old 11-07-2012, 08:33 PM Thread Starter
Shoot, I replaced both pulleys and belt already. Noise went away for about a day, then came back. I've been spraying wd on it to quiet it lately, but want to fix it permanently. Looks like the tensioner pulley is slightly off alignment horizontally. Maybe the arm has just bent a bit over the 120k miles...? Dunno.
Everything is clean and tight. I pulled it apart last night, cleaned everything with degreaser, rinsed with water, dried, and put a light coat of white lithium grease on the pivot points. Noise was louder than before, but there was no wd on the smooth side of the pulley anymore...
post #6 of 11 (permalink) Old 11-07-2012, 08:46 PM
wjc
wjc's Avatar
The tensioner arm has worn out, the new part should be the fix.
wjc is offline
post #7 of 11 (permalink) Old 11-08-2012, 08:44 AM
Have had the same problem as TaurusSE98. Replaced the idler & tensioner pulleys-squeak came back. Replaced belt with a Dayco-squeak still there. Bought a Motorcraft tensioner and installed-squeak still there. Per other postings on this site--bought a Gatorback belt at Goodyear ($56)-and squeak stopped. Solved the problem, but deep down I feel I'm just covering up a problem that's going to involve replacing the water pump--but it doesn't leak and car never overheats. When belt was squeaking, just a teeny squirt of WD-40 would stop it for a few minutes.
P.S.: I have 2002 3.0L Vulcan--Goodyear part number for the Gatorback is: 4060855. When I searched online for the belt, Goodyear would give lengths of the belts in inches, but wouldn't let you plug in your engine type and get a part number. Local Goodyear guy finally coughed up the part number when I pressed him, but confirmed what I said.
jimbeamalki is offline
post #8 of 11 (permalink) Old 11-08-2012, 11:10 AM
Had anything done to the steering pump? That pulley is a slide on-pressure fit to the shaft and can be out. The shaft should be flush with the outer edge of the pulley. Can feel it with your finger.
I wouldn't use WD-40. A bar of bath soap rubbed (don't catch your finger or hand) on the running belt surfaces lasts a good long time and doesn't deteriorate rubber.
willyum is offline
post #9 of 11 (permalink) Old 11-08-2012, 01:32 PM Thread Starter
I tried soap, but it didn't do anything. I'l have to check the PS pulley but everything looked straight except the tensioner pulley from what I can tell.
post #10 of 11 (permalink) Old 11-08-2012, 02:12 PM
A mis aligned belt will likely wear out in quick time or just jump off. My tensioner pulley doesn't run in the belt grooves so perfect alignment isn't critical.
You must be chasing a ghost.
willyum is offline
