The Mysterious Ticking Noise - Taurus Car Club of America : Ford Taurus Forum
post #1 of 16 (permalink) Old 10-29-2012, 04:09 PM Thread Starter
redhousenine's Avatar
I have this annoying ticking sound in my 2005 Taurus that comes and goes whenever it wants. It sounds like its coming from the underside of the dash by the defroster vent, somewhere between the center and the passenger's side of the dash.
This started some time after I acquired the car. At first it sounded like it came from behind the A-pillar trim. Had it off for a while but it wasn't the source of the sound. Then I thought the ticking noise was coming from the passenger side vent. Removed the vent and applied felt to the pressure points. (Write-up here). After that, no more ticking noises for about 2 months, and I was certain that I finally silenced that noise.
Today when I started the car, the ticking noise was back, louder than before. It was also ticking when idling, something that never happened before as it only did it while the vehicle was moving. It was also ticking after I turned the car off. Not sure it is temperature related as I heard it tick after the car has been in the sun and after being in the cold garage.
However, the tick sounded different this time. Before it sounded like plastic rubbing against vinyl, now it sounds like a metallic noise; something similar to crackling hot coals in a fire pit, or even aluminum foil. I am 100% certain now that it is coming from right under the dash.
Does anyone have any thoughts about this? I am at my whitís end with this tick. My guess is that it could be a wire harness, rubbing the right way against something.
I am aware of the blend door tick issue. That isn't the source of the sound.
redhousenine is offline
post #2 of 16 (permalink) Old 10-29-2012, 04:19 PM
Year: 1996
Model: Mercury Sable Wagon
Were you able to determine if it is related to the blower fan in anyway? Does it happen if the blower if off?
nbpt100 is offline
post #3 of 16 (permalink) Old 10-29-2012, 04:22 PM
Exalted Grand Poobah
Lgbpop's Avatar
Year: 1990
Only thing I can think of is old, dried leaves in the HVAC ductwork. When I had my cowl area apart last March I found bits of leaves jammed in the blower vanes, which probably used to be whole but whapped themselves to pieces every time I ran the blower. What blows that theory up is that you have a cowl filter for your fresh-air intake. Perhaps your system sucked something in from the footwell some time when your recirculation damper was closed.
Lgbpop is offline
post #4 of 16 (permalink) Old 10-29-2012, 04:54 PM
breeves002
Sam's Avatar
Year: 2008
Engine: 3.5L Ti-VCT V6
Trader Score: 8 reviews
It's a time bomb waiting to go off. Probably something rubbing against the blower. I've heard people having ticking noises for the blend door actuator motor as well. Not sure if that matches your symptoms though.
2016 Ford Mustang GT Premium
2014 Ford Focus Electric
Moved On:
2008 Mercury Sable Premier
2000 Sable LS Premium Duratec
1997 Mercury Grand Marquis GS
Sam is offline
post #5 of 16 (permalink) Old 10-29-2012, 05:17 PM Thread Starter
It happens if the blower motor is on or off.
Removing and cleaning the wiper cowl is the next step, but it will have to wait until the weather clears up.
post #6 of 16 (permalink) Old 10-29-2012, 06:23 PM
Lgbpop's Avatar
Year: 1990
Good luck with the wiper cowl, but your noise sounds as if it's inside the car. A lot of us have had dried leaves in the ductwork (not limited to Fords, either) and the only way to clean them out altogether is removing the dash to get to the heater box and ducts.
Lgbpop is offline
post #7 of 16 (permalink) Old 10-29-2012, 07:41 PM
mjhpadi's Avatar
It sounds like the blend door actuator...it's a fairly common Ford problem.
2010 Ford Taurus SHO-Livernois 4+X Tune, Airaid CAI, Caliper Covers, Tinted Taillights, Tinted Headlights, LED Interior Lighting, LED Puddle Lamps and License Lights, SHO Hood Stripes, Rearranged Trunk Badging, 3 Bar MAP Sensor, 160 Evenflo Thermostat, V3 Triton Switchback LED Front Parking/Turn Signal, EBC Slotted/Dimpled Rotors w/EBC Yellowstuff Pads
2013 Ford Explorer Limited-Wife's Tow Vehicle
1999 Ford Taurus SE Wagon-'Our Family Truckster"
mjhpadi is offline
post #8 of 16 (permalink) Old 10-30-2012, 10:28 AM
I agree with the blend door actuator. If it's stripped, it will try to open/close the blend door and slip by causing the clicking. Try adjusting the heat level and see if it causes it to click more or on demand for a temp change.
Bob R is offline
post #9 of 16 (permalink) Old 10-30-2012, 05:46 PM Thread Starter
Drove the car today under the same weather conditions as yesterday. The ticking noise was gone!
As mentioned in my first post, the door blend actuator is not at fault.
Also, does anyone here have hi-res pictures of the underside of a gen 4 dash when removed? Maybe I can get an idea on what might be causing the ticking noise.
post #10 of 16 (permalink) Old 10-30-2012, 05:48 PM
breeves002
Sam's Avatar
Year: 2008
Did you check if something was rubbing against the blower motor? What side under the dash is the noise coming from?
EDIT: Wait... you said it happens if the blower is on or off. So probably not it. Still, what side did you hear it from?
Is it a constant noise when it happens? Or is it in a random pattern? Will it start and stop randomly like during a drive?
Moved On:
Sam is offline
