intermittent starting issue - Taurus Car Club of America : Ford Taurus Forum
post #1 of 6 (permalink) Old 10-02-2012, 03:32 PM Thread Starter
My wife's 2003 Taurus has developed an intermittent starting issue.
Once every couple of weeks or so it will not start. It follows no pattern (as in cold/hot). Dash lights come on, but no clicking/cranking, or any other noise. Every time so far, if you turn the key 5 or six times, it will start, and then everything's fine until the next time.
The car has a new battery, alt., starter, starter relay. I checked the battery terminals and they seem fine.
Could the ignition switch itself be going out?
I read a post from maxx powers that mentioned a "known problem with the 'ign' terminal on the starter". Is this more likely?
Any ideas would be appreciated.
dssenne is offline
post #2 of 6 (permalink) Old 10-02-2012, 04:04 PM
i had a similar problem in my 06 vulcan, it was the starter binding up, had it replaced 2 times with ford staarters, complained to ford; they said screw you.
tesmith47 is offline
post #3 of 6 (permalink) Old 10-02-2012, 07:35 PM
Year: 1999
Model: Ford Taurus Wagon
hi, on my wife 99 sable, the new starter came
with a pigtail to replace the existing lead to the
relay.
regards
james27613 is offline
post #4 of 6 (permalink) Old 10-02-2012, 08:01 PM
tylerdahl's Avatar
i had same problem with my starter a few times it kept binding up and the starter would smoke if it kept trying to start it! ended up being a problem with the teeth on my flywheel! was costly repair, but the problem was fixed.
yes it's a SHO, make an offer!
1992 Ford taurus GL/ the backup.
1993 Ford taurus SHO/ The Toy.
2003 Ford taurus SEL/ daily driver.
tylerdahl is offline
post #5 of 6 (permalink) Old 10-06-2012, 12:29 PM Thread Starter
The starter doesn't seem to be binding. When it starts (which is 99% of the time), everything is normal. I've had problems with starters in other cars, and this is different. When this one doesn't start, it just doesn't do anything. No turning over, no noises, clicks, or anything.
dssenne is offline
post #6 of 6 (permalink) Old 10-06-2012, 02:43 PM
breeves002
Sam's Avatar
Year: 2008
Engine: 3.5L Ti-VCT V6
Trader Score: 8 reviews
I have had the exact same problem as you about 5 times in the life of the car (2000-now). It is the most odd experience. It does nothing at all, no noises no nothing. I feel like there was some weird sequence of actions you could do and it would start, but usually if I just waited it would eventually work. It was bizarre.
2016 Ford Mustang GT Premium
2014 Ford Focus Electric
Moved On:
2008 Mercury Sable Premier
2000 Sable LS Premium Duratec
1997 Mercury Grand Marquis GS
Sam is offline
