Codes P2197, P2270, P1000 - Taurus Car Club of America : Ford Taurus Forum
post #1 of 8 (permalink) Old 08-02-2012, 08:07 PM Thread Starter
My car is an 04' Taurus with the 24v DOHC engine. I keep getting the code P2197, P2270 which is oxygen sensor stuck lean. and P1000 OBD test incomplete.
The car does have power loss every now and then, plus an exhaust smell that comes in trough the ventilation and you can smell it when you are standing next to the drivers or passengers front door. Plus there is t a lot of heat dissipating from the same area.
I did order an new DPFE sensor and installed it.
I think my cat is blocked.
Any advice and tips would be very much appreciated.
MarcPhotoMan is offline
post #2 of 8 (permalink) Old 08-02-2012, 08:25 PM
P1000 mean the codes have been recently cleared or the battery was disconnected. If you haven't done either of these recently, it may be cause for concern.
You have lean codes for two oxygen sensors - Bank 2 sensor 1 and Bank 1 sensor 2. You could have a vacuum leak somewhere, but it could also be some kind exhaust leak as well. It might also be bad oxygen sensors. Start by checking for vacuum and exhaust leaks.
behlinla is offline
post #3 of 8 (permalink) Old 08-03-2012, 05:37 AM Thread Starter
Yes Codes were cleared and the battery was disconnected, I checked for Vacuum leaks, like I said I do smell exhaust coming from under the car near under the front of the car near the driver and passengers doors.
My gas mileage sucks and the car hesitates (with some power loss) from time to time and tends to idle funny from time to time. especially after going over a speed bump. Also the heat shield is rattling.
I proably do need to change the plugs and gas filter ( I do not know when the previous owner changed them). But I want to tackle one thing at at time.
What is the best way to find an exhaust leak?
post #4 of 8 (permalink) Old 08-03-2012, 08:00 AM
I am betting on a massive vacuum leak.
post #5 of 8 (permalink) Old 08-03-2012, 02:55 PM Thread Starter
I had an oil change done today at Midas. While I was there I had them look for an exhaust leak, So there estimate says that i need to change Gaskets: 1 Manifold & 1 Flange; Emission Restrictions:
Rear Manifold Conv.;and 2nd cat and both oxygen sensors
I am not sure if i need to change all these parts but at least I know what to look at.
post #6 of 8 (permalink) Old 08-03-2012, 09:24 PM
DO NOT trust any "diagnosis" from a chain store like Midas. They are complete rip off artists!!!! If you arent going to diagnose and fix it yourself, find a trusted mom and pop repair shop.
post #7 of 8 (permalink) Old 08-04-2012, 07:05 AM Thread Starter
I needed an oil change and they had a special. I wanted to ge an idea of were to look before I get under the car. I do not trust them and I never said I was not going to fix it my self!
post #8 of 8 (permalink) Old 02-23-2013, 12:21 PM
Thumbs up marcphotoman
Places like Midas and such are not to be trusted any further than you can throw your car (my view). A quick way to do a check is to take it to the place that uses the oil that you want. Say, Jiffy Lube for Pennzoil. They, like the dealership will do all the extra checks...whether you want them to or not. This is ok...just remember that YOU want them to do ONLY what you brought the car to them for..NOTHING else. So they come in and tell you this is low or that is low...and to give them a little credit, they may be right. Like the oil level may be a hair (I am not kidding...a hair) below the full line. Then you say top it off, they add a tablespoon and charge you for a qt. I think enough of the TV networks have done exposes on these shops to at least warrant you being extremely careful. So back to the inspection. Let them go through the trouble of removing your cabin filter (Yes, most of you have them) and they will show you all the leaves, etc that are on it. Tell them no, you don't want it changed at this time. Good answer for everything they say. Next, when you get home, you can top off the fluids, etc. You can go to Advance and buy a cabin filter and if you don't know where it is, just watch when they go back after you say no, and see where they put it. Believe me, it is cheaper to spend 5 minutes changing it out than it is to have them do it....a lot cheaper.
Dandur805 is offline
