Motor Mount/Vibration - Taurus Car Club of America : Ford Taurus Forum
post #1 of 5 (permalink) Old 07-31-2012, 08:14 PM Thread Starter
I have a 2004 Sable with the DOHC engine. The car has 125,000 miles on it. Recently I had the rims, tires replaced and balanced, and new shocks and springs (Quickstrut). The car vibrates at 75+ MPH. Took the car back to Belle Tire and they said all wheels are balanced…and it could be a drivetrain problem. I noticed when I start the car there is a squeaking noise while the engine is turning over. Once the engine is started I hear the squeaking noise when I stop the car, when I go over bumps, and when the car is going over 75 MPH. I am thinking this may be the engine mounts. While the car was off and in park I rocked the car back and forth, I noticed the engine moves back and forth and the squeaking noise occurs while the engine is rocking. This is not the worst movement I have seen but enough to cause a squeaking noise. I also started the car and had a helper shift between drive and reverse. While going from reverse to drive the engine moves towards the firewall quite a bit and the squeaking noise occurs. While going from drive to reverse the engine barely moves and the squeaking noise does not occur.
Any advice is greatly appreciated.
roadman1977 is offline
post #2 of 5 (permalink) Old 07-31-2012, 09:21 PM
wjc
wjc's Avatar
Yeah, it may be mounts. I don't know that would cause a vibration, but the drive belt could be rubbing on something causing the squeaking as the engine shifts.
wjc is offline
post #3 of 5 (permalink) Old 07-31-2012, 09:30 PM Thread Starter
From what I have read the rear mount takes most of the stress and breaks first. Is the passenger rear mount a real PITA??? I have average mechanical abilities. Does this job require superman strength??
post #4 of 5 (permalink) Old 07-31-2012, 09:55 PM
The dog bone support ususally cracks and loses it's strength first. The ensuing torque eventually breaks down the bottom mounts. Check to dog bone first.
willyum is offline
post #5 of 5 (permalink) Old 07-31-2012, 10:08 PM
^ No dog bone on his tec.
