what are the symptons of a faulty blend door actuator? - Taurus Car Club of America : Ford Taurus Forum
post #1 of 5 (permalink) Old 05-14-2012, 06:37 PM Thread Starter
what are the symptoms of a faulty blend door actuator?
peterf1992 is offline
post #2 of 5 (permalink) Old 05-14-2012, 06:39 PM
N.E. Chapter Moderator
Trader Score: 7 reviews
One major thing that can happen is that no matter what setting, it won't blow out your dash vents. Just the windshield vents. It defaults that way so you can have defrost available if there is an issue with it.
2011 Ford Fusion SEL 3.0L DOHC V6
2005 Mercury Sable LS Platinum Edition 3.0L DOHC V6 (The Beater)
2005 Ford Taurus SE 3.0L FFV OHV V6 (Sold)
2006 Ford Taurus SE 3.0L OHV V6 (Sold)
2005 Ford Taurus SEL 3.0L FFV OHV V6 (Sold)
2007 Ford Taurus SE 3.0L OHV V6 (Sold)
1999 Ford Taurus SE 3.0L OHV V6 (Sold)
TaurusDailyDriver is offline
post #3 of 5 (permalink) Old 05-14-2012, 08:46 PM
^ The "default to defrost" is due to an hvac vacuum leak. With a faulty bda, you'll probably hear a clicking (thumping) in the dash (plastic gears stripped) and won't be able to regulate temperature. Remember, vent (mode) selection is vacuum controlled. Temp. selection is elec. controlled via the bda.
post #4 of 5 (permalink) Old 05-15-2012, 01:04 PM
Year: 1997
Model: Ford Taurus Wagon
We're entering the cooling season, and a 'broken' blend door defaults to cooling, so you've got some time to fix this problem. It's in the winter when you want heat that a malfunctioning blend door becomes a problem. I propped mine up for awhile with a small piece of plastic jammed into that silver sliver bar to keep the door in the 'heat' position until I replaced the Actuator (which had cracked teeth on one of the gears). The replacement's been in there for about 5-7 years, but just recently I heard a noise coming from underneath the dash again. If it's the Actuator (again), I guess they only last for about 7 years before the plastic gears inside fail!
Colt Hero is offline
post #5 of 5 (permalink) Old 05-15-2012, 09:14 PM
^+1. They (bda) usually (not always) fail to cold.
