04 Taurus vacuum line diagram - Taurus Car Club of America : Ford Taurus Forum
post #1 of 8 (permalink) Old 03-31-2012, 02:03 PM Thread Starter
CB7Mainer's Avatar
Does any one know where to find a vacuum line diagram for an 04 Taurus. The little one under the hood doesnt show much. The reason I ask is because today when I was checking my oil, I noticed a elec conection that wasn't hooked up. And it goes to something with two vacuum lines in it. Its next to the intake pluntum on the pass side. Its round and you can turn the top of the part. I'm just trying to find out what it is and if it could cause my bad gas milage. Thanks in advance for the help.
1998 Taurus SE Comfort 3.0L Duratech
2004 Taurus SES 3.0L Duratech
May the road rise up to meet you, and the wind always be to your back.
CB7Mainer is offline
post #2 of 8 (permalink) Old 03-31-2012, 02:13 PM
That is the EGR vacuum solenoid. It should be plugged in. It will set a code if left undone. Doubt it does all that much for the mpg.
chartmaker is online now
post #3 of 8 (permalink) Old 03-31-2012, 02:18 PM Thread Starter
CB7Mainer's Avatar
I didnt have any codes. And the cel didnt come on. I had the coils done not to long ago and they had to remove the intake. Looks like they forgot something. lol. Would that make the car run like crap? Cause mines been running very good. Just seems like its eating more gas then when I got the car. My wifes 98 gets better gas milage then mine. Thanks.
post #4 of 8 (permalink) Old 04-01-2012, 09:41 AM
if they forgot to plug the electrical plug back in, they probably did not notice the vacum line that is now unplugged under the throttle body.
This line is hard to see but is tucked in there and seems to come off every time i pull off the UIM.
retiredtaurus is offline
post #5 of 8 (permalink) Old 04-01-2012, 09:56 AM
Does the CEL even work? Does it light up when the key is turned to RUN? It should. As Chart said, if EGR solenoid electrical connector is unplugged, the CCM (constant component monitor) should pick this up instantly and turn on the CEL. Is this a relatively "new to you" car? I hate to say it, but sometimes the PO (or shady used car dealer) will remove the CEL bulb if the CEL is on to make the car appear trouble free.
post #6 of 8 (permalink) Old 04-01-2012, 11:55 AM
I left the vac line off the EGR valve and made a long trip. The light did come on, but as I remember it was a while into the trip. Also a "pending code" will not light the light. Different things require different number of errors.
However, I left the air temp wire off the air cleaner housing on a Lin while changing the air filter, and the light came on immediately on start.
Starting to sound like I FORGET things!
Guess I am the only one who does that. I try not repeat mistakes, but there seems to be a huge supply of missing or not tightend things on a car to do.
post #7 of 8 (permalink) Old 04-01-2012, 09:10 PM
wjc
wjc's Avatar
The more stuff you know, the more stuff there is to forget. So really, all of my mistakes are due to my superior knowledge. At least that's how I try to sell it...
wjc is offline
post #8 of 8 (permalink) Old 04-05-2012, 07:47 AM Thread Starter
CB7Mainer's Avatar
The cel light works. Ive had it come on cause of a bad upstream o2 sensor. Ill have to hook it up and see if there are any codes stored on the computer. Thanks everyone for the help.
