Erratic Idle - Taurus Car Club of America : Ford Taurus Forum
post #1 of 9 (permalink) Old 03-17-2012, 03:59 AM Thread Starter
Question Erratic Idle, 2007 Vulcan 3.0
My 2007 Taurus, 3.0 Vulcan, has a very erratic idle. It goes anywhere from 600 to 750, up and down, very quickly and constantly. Otherwise, the car is running fine. The fuel mileage is still good. The A/C makes no difference. Every once in a while, the engine stumbles when idling, too. I don't know what to make of this -- if the car was an old one, I would say there was a vacuum leak. The car has 77,000 miles and has had meticulous maintenance. Any suggestions?
davejonmarsh is offline
post #2 of 9 (permalink) Old 03-17-2012, 05:07 AM
More meticulous maintenance and check the Idle Air Control on top of the Throttle body. Try cleaning with Mineral Spirits and Q-tip in the 2 holes in the bottom when removed. Put a new gasket on it. Mine only does that idle change when my A/C cycles when I am sitting at stops. When my controls for defrost are on it will do it and when the controls are on heat or vent it will not. My 2 are a 2000 flex and a 2003. Both Vulcans. Get good mileage with both.
downhill is offline
post #3 of 9 (permalink) Old 03-17-2012, 07:52 AM
Agree on Q-tip and mineal spirits. See pic. This I picked up at the JY and it was stuck. Hugely dirty, could not move the piston with a tooth pick. Cleaned with mineral spirits and Q-tips to remove the oily part. Then cleaned with household ammonia and Q-tips till visually clean. Oiled the arrow points and wiped the excess off with a Q-tip. Put on my Lin Cont and is working perfect for 6 weeks. If it continues after 6 months I will consider this method successful. Then I will consider putting the original back on the car.
post #4 of 9 (permalink) Old 03-22-2012, 04:04 AM Thread Starter
It wasn't the IAC or the PCV valve
I checked both the IAC and the PCV, and both were clean and functioning. I am stymied. No check engine light. Should I just cave in and take it to the mechanic to run codes for me? I am beginning to suspect it is something electrical.
post #5 of 9 (permalink) Old 03-22-2012, 05:41 AM
901-Memphis's Avatar
Lots of Vulcan running rough issues. I have had more than my share in the past, what type of plugs are on it and what are their condition?
1999 Vulcan Sedan with 145k+
901-Memphis is offline
post #6 of 9 (permalink) Old 06-04-2012, 01:31 AM
Is the picture you posted from a duratec IAC? I have the vulcan engine, and the IAC I have does not have the spring and shaft extending to the 2nd hole as shown in the bottom portion of your picture.
Trabucodom is offline
post #7 of 9 (permalink) Old 07-06-2012, 11:22 PM
Ben
I Drive A Fuze
Ben's Avatar
Looks to be a Duratec IAC from pre 2004 cars, because mine looks completely different than that (2004 Duratec).
The Toy
Ben is offline
post #8 of 9 (permalink) Old 07-06-2012, 11:45 PM
Above pic is of an iac, not pcv.
post #9 of 9 (permalink) Old 07-06-2012, 11:46 PM
Ben
I Drive A Fuze
Ben's Avatar
Whoops! Just caught that mistake, thank you Shiela! I meant IAC, don't know why I put PCV
The Toy
Ben is offline
