Troubleshooting/resetting a P0420 Code - Taurus Car Club of America : Ford Taurus Forum
post #1 of 5 (permalink) Old 03-04-2012, 11:48 AM Thread Starter
I recently bought a 2006 Ford Taurus. I got it inspected after buying it, and it passed inspection and emissions. Took it home two days ago. Last night the check engine light came out, and when I got it scanned it gave a P0420 - which, from other forums, indicates catalytic converter problem, but also may be o2 sensors.
The car has been sitting for a while. One recommendation I got is to reset the code and drive it at highway speed for a while, and see if it comes back on, to see if it just might be a result of it sitting idle for some time.
So, the question I have is, how can I get the code reset? I've heard that you can do this by disconnecting the battery, but I've also heard people recommend that you NOT do this.
Thanks!
JordanB is offline
post #2 of 5 (permalink) Old 03-04-2012, 11:52 AM
danhasenauer's Avatar
The battery disconnect will usually do it, but I like to go to AAP, borrow their scanner and do it myself in their parking lot. Another nifty reason to invest in your own good quality handheld scanner.
'96 LX DOHC Moonlight Blue
RIP 'Ol Blue - 09/2012
danhasenauer is offline
post #3 of 5 (permalink) Old 03-04-2012, 12:02 PM
I've got the same car. Having the somewhat problem, my code comes up after it been erased in about 3 or 4 days, I would guess that the dealer did the same for that car. Had the code erased just before you got the car. Read my problem on P0420 post, may help you.
Also that car has a problem with code that states multiple miss fires, there is a fix at the dealer that they reprogram it to widen the specs, it's in a tech bulletin, but I think they might charge for it. Lee
lee231 is offline
post #4 of 5 (permalink) Old 03-04-2012, 12:21 PM
Year: 94
Engine: 3.8L Essex
Thanks!
The P0420 code is for the bank one cat efficiency being below threshold, which if the O2 sensor is ok, suggests a problem with cyl bank-1 cat converter.
All that said, cats don't usually just die prematurly, something usually causes their demise, so we need to look up stream for a cause, like a coolant leak, fuel trim problem, ect, that you would want to put right Before replacing the cat converter, lest the new one be put down too!!!!
SO, if you have other trouble codes, post All code Numbers you have.
Disconnecting the battery B- cable will erase the code, but will also wipe the KAM, which includes the fuel trim & base idle memory, so to prevent possible driveability problems, you'll want to at least do a cold & warm idle relearn routine listed here. Can Someone Tell Me How To Reset My Check Engine Light?
More thoughts for consideration, let us know how it goes.
94 Taurus GL 3.8L PEP204A
99 Ranger 4dr 4.0L 5spd Auto
Payload & Tow Pkg
pawpaw is offline
post #5 of 5 (permalink) Old 03-04-2012, 01:19 PM
I'll Be Watching You!
sousa632's Avatar
Model: Mercury Sable Wagon
The misfire is causing the p0420. Raw fuel dumping into the cat and clogging it, thereby causing an 'inefficiant flow' code. Mix the misfire, then worry about the cat.
John
2001 Sable LS Premium Wagon Duratec, 193K miles and kicking, 99 Durango 318, 2013 Hyundai Sonata GLS
sousa632 is offline
