2007 SEL Alternator going out? - Taurus Car Club of America : Ford Taurus Forum
post #1 of 9 (permalink) Old 01-02-2012, 09:14 PM Thread Starter
SUP
Got home from being out of town for 2 weeks. Cranked the 2007 Taurus SEL with 124,000 miles. Cranked a bit rough. Let it idle a bit and took off a few minutes later to get gasoline and food.
On the way to get gas and food, I noticed the dash lights were a bit dimmer than normal. I tried adjusting them / nothing improved it. After getting food and gas en route to the house, it got a bit worse. Even the air bag light came on.
The battery was replaced by Ford in Aug. 2010 and has a 5 year warranty. In the old days, this sounds like an alternator problem. I was not having any issues prior to returning from 2 weeks out of town however.
Any ideas out there or confirmation of my thoughts?
SUP
SUP is offline
post #2 of 9 (permalink) Old 01-02-2012, 09:28 PM
CJpilot's Avatar
Trader Score: 3 reviews
SUP
Sounds like the alternator.
Mine did that, but the battery light had been on for several hundred miles before it did this. Once it did start showing the symptoms you say, it only had maybe 25 miles before it died. It was the alternator, $250 for a new one from a local shop.
I would take it to a shop ASAP to have it checked...otherwise you may end up stranded.
Cody A.
2005 Ford Taurus SE- 3.0 Vulcan FFV
2000 Ford Taurus SE- 3.0 Vulcan -Retired
1986 Cessna 172P- Lycoming O-320-DJ2
CJpilot is offline
post #3 of 9 (permalink) Old 01-02-2012, 09:31 PM
SUP
If you have the electronic message center you can check you alt voltage by entering the Engineering test mode.
hold the reset button and turn key to on ETM should come up on display. the first test will be the instument guage test. your guages will shake for a few then go all the way up and back down. you can start the car and toggle the reset switch until you get to the battery voltage. If the alternator is good you should have at least 14v with car running.
if not you have bad alt.
hope this helps
dan
Truck55 is offline
post #4 of 9 (permalink) Old 01-02-2012, 09:44 PM
Trader Score: 7 reviews
If you can, pop the alternator out and go get it tested.
I replaced a friends alternator on his 2007 Ford Taurus. Easy job, but sad that at 68K miles it had bad diodes.
--Nick
bull geek is offline
post #5 of 9 (permalink) Old 01-02-2012, 10:15 PM Thread Starter
SUP
Looks like an easy replacement. I think I will just take it out in morning and run it down and have it tested. If it starts fine, I may run the check that Truck 55 describes as aI do have the electronic message center.
SUP
SUP is offline
post #6 of 9 (permalink) Old 01-02-2012, 11:31 PM
I'll Be Watching You!
sousa632's Avatar
Model: Mercury Sable Wagon
Get a multimeter and test voltage at the battery after starting. It should be 14.2v+. If it's not, the alternator is bad or the belt is slipping due to a bad tensioner or something else.
John
2001 Sable LS Premium Wagon Duratec, 193K miles and kicking, 99 Durango 318, 2013 Hyundai Sonata GLS
sousa632 is offline
post #7 of 9 (permalink) Old 01-04-2012, 08:30 PM Thread Starter
SUP
Well I took out the alternator and took it to be tested. It was barely kicking in any volts. Bought a new one, put it on and it works. I also charged the battery while I was away and while I was doing the work. All is well and the indicator lights have gone off.
SUP
SUP is offline
post #8 of 9 (permalink) Old 01-04-2012, 10:04 PM
SoNic67's Avatar
SUP
You did good that you charged the battery before starting the new alternator. See below why.
Usually those go out when the alternator tries to charge an empty battery - the current is too high for them in that case.
When the car sits for a long time, especially in cold temperatures, sometimes an old battery discharges too much. Or if a light is left on inside the car. And that empty battery takes down the alternator with it...
SoNic67 is offline
post #9 of 9 (permalink) Old 01-05-2012, 08:51 PM Thread Starter
SUP
Did not know that. The battery was only a year old but the car set up for two weeks without being used. It was garaged however. My other vehicle cranked right up as did the Taurus but the Taurus did not hold the charge.
I just felt it would be better starting off with a recharged battery and new alternator. Glad I did!
SUP
SUP is offline
