Member Number: 23577
Hi All, we have a 2001 Taurus LX OHV and I think the water pump is bad & needs to be replaced. The radiator fluid was spraying out of a small hole in the overflow bottle. After we changed the overflow bottle the leak was still there. Took another look and see radiator fluid coming out of the water pump weep hole. Can't find my Haynes manual and don't want to spend all day looking for it. Does someone have a step-by-step on how to change out the water pump?(pictures would be nice too). I am also going to look at the hoses and probably change out the thermostat as well (or should I leave it alone). Also, in checking the past threads on water pump repairs, I saw a few threads that mentioned flushing out the heater. Is this necessary and How would I do that? Once again I appreciate all the help and advice and I want to thank everyone in advance for their assistance.
#2 (permalink) | |
Member Number: 3136
Drives: 1998 LX black Vulcan
1997 SE black Vulcan
Bob Urz 1989 Vulcan wagon (wife crashed) 1990 Vulcan sedan (sold running) 1993 Vulcan sedan (wife crashed) 1993 Vulcan wagon (beat up like Battlestar Galactica, drove to junkyard on a sad day) 1997 Vulcan sedan daily driver, 1998 Vulcan sedan (recovered from daughter) If Spock drove a Taurus it would be a Vulcan Last edited by soundu; 12-18-2011 at 11:01 AM. |
Thanks for the quick reply. Good tip on loosening the water pump bolts BEFORE removing the serpentine belt. The car never ran hot so I don't think (hope) the head gasket is toast. Is it possible the head gasket could go if the water temp gauge never peaked, nor ever got past the middle of the gauge? This all started will the car spitting out the radiator fluid after a short drive. My son saw the little hole in the overflow bottle & we thought that the radiator must have been loosing pressure and boiling over at a lower temp because the system wasn't under the pressure(needed to be able to heat the coolant to a higher temp without boil-over). Now that we changed out the overflow bottle there is a radiator fluid leak after running the car for a few mins. I checked and see fluid at the weep hole so I figure that should be next to change. What is a good way to tell if the head gasket is gone? It's kind of strange with the domino effect going on(ie; 1st the overflow bottle, fix that and now the weep hole leak). Thoughts??
Member Number: 33869
Rep Power: 4 ![]() |
There is a step by step in the Topic Finder of you take a peek. Soundu summed it up well. If you get the belt and tensioners out of way and start with out belt you can check and make sure timing cover is not leaking too!! You can warm car up enough to get some pressure on the system to double check before you start pulling parts. I had a bad pump gasket after 112K on one I bought and the timing cover was leaking too!! Hard job but necessary!
Good luck. Put in a new one, they are worth it. I found one new for $35 at Napa. NOT Chinese junk! |
Thanks again for the help. I'm probably missing it but I couldn't find a link under the "topic Finder" for the Vulcan water pump step-by-step. I saw the one for the Duratec, but our 2001 LX has the Vulcan engine, although I might be wrong. Can you post the link to the step-by-step in a reply? That would be very helpful! And am I correct in thinking that the water pump is external to the engine, even though we have to remove the serpentine belt and move the alternator & idler pulley to access it. My brother was telling me it is an internal water pump which I told him to be wrong. Again thanks in advance for all the help and assistance you can offer.
Member Number: 113 Join Date: Nov 2002 Location: Houston, Texas Visit: My Garage Posts: 6,435 Trader Score: 0 reviews Rep Power: 16 ![]() OK, I bumped it, so it should be right below this post. WATER PUMP posted by dmart12 diy instructions. disconnect neg. battery cable. open radiator petcock(driver's side) or remove lower radiator hose from radiator. drain coolant. take 8 or 10mm wrench(I've seen both), loosen w/p pulley bolts. remove serpentine belt. remove 4 bolts from pulley and remove pulley. remove small bracket from top of alternator(8mm wrench). remove 13mm bolt from alternator and loosen 15mm bolt on alternator then flip alternator out of way, slightly snug the 15mm bolt. remove 7 8mm bolts holding water pump. there is one directly center beneath the shaft(hard to see) do not forget this!! remove 4 13mm bolts holding water pump (2 each side). remove water pump (tap lightly with hammer usually). clean all remnants of old gasket material. reverse for install. that's basically it off the top of my head. This was posted by a late member and is the correct sequence of events for the repair. downhill |
#7 (permalink) | |
Member Number: 3136
Member Number: 34109
Drives: 2004 Ford Taurus SES, 3.0 liter 24 valve DOHC v-6 Duratec engine
Rep Power: 3 ![]() |
Maybe this will help.
Brian 2004 Ford Taurus SES, 3.0 liter 24 valve DOHC V-6 Duratec engine 1999 Ford Taurus SE, 3.0 V-6 2001 Ford F250 Super Duty Lariat, Crew Cab, 5.4 liter V-8 gas motor, 2WD, 410 LS Rear Axle |
#9 (permalink) |
Member Number: 35931
Drives: 03 sable wagon
As for checking your head gasket, you can usually take your dipstick, and get another car that is running and HOT. Drop a few drops of oil from your dipstick on it and see what it does. Oil does not boil, it burns, so if it sizzles, you have water in your oil. If it just kind of seeps and smokes you are in good shape.
Overall changing water pump alone is easy job, much easier then front cover assembly. (Which by the way can also lead to you getting water in your oil...) The only true way to check for a blown head gasket is by using a "Combustion Leak Test Kit" which actually checks for exhaust gasses in your coolant system. (Which means your head gasket is bad or you have a crack in your head.) |
#10 (permalink) |
Member Number: 7669
Drives: 2001 SES Vulcan OHV (U)
Rep Power: 8 ![]() |
I documented a water pump R&R as well as timing chain cover gasket R/R in this wiki.
