2000 Taurus SEL duratec P0171/P0174 leading to P0301 - Taurus Car Club of America : Ford Taurus Forum
post #1 of 8 (permalink) Old 12-15-2011, 03:36 PM Thread Starter
I think I am headed in the right direction but need to know possible cause of misfire.
History - 2000 taurus SEL duratec DOHC, 189,000 miles. I used to be a service advisor for Ford dealer and have done maintenance myself in the past on this car, bought it new in 2000. Engine had rough idle when engine is cold but ran fine when engine warmed up. Had this for a couple of months but just thought it was the IAC and would replace when I did my tune-up. On 11/30/11, CEL came on with P0171,P0174, P0301 and also had some vacuum leaks you could hear so on with the tune-up.
Replaced plugs (motorcraft), upper intake manifold gaskets, PCV valve (hose not cracked), replaced recirc vacuum lines from valve covers to side of air intake at the throttle body (both cracked completely disconnected).
Ran fine for a few days then CEL back on. Codes this time, P0401, P0171, P0174, P1504. Went ahead and replaced throttle pos. sensor and IAC but knew I was dealing with vacuum leak.
Ran good for a couple days and CEL back on. Codes now were P0122, P1504, P0171, P0174, P0301. Did not clear codes yet, wanted to change DPFE first.
Went today to purchase DPFE, not installed yet, however, went ahead and cleared all the codes today due to engine vibrating violently, and sputtering all gears and speeds. Felt like a misfire. CEL back on in a few miles and flashing this time, checked codes and got P0401 (have the DPFE to replace), and P0301.
I will replace the DPFE but I have kept getting this P0301 for cylinder #1 misfire even after I changed out the plugs.
My question is, does anyone think the EGR insufficient flow could cause one of the new plugs to foul or could the coil pack for #1 cylinder finally have gone bad and just be a coincidence? Or will this improve with changing the DPFE? I don't want to throw a new coil pack at it if it could all just be from the DPFE or a clogged EGR (although EGR did not looked clogged when I changed the plugs).
Sorry for the long post but wanted to give all the background info.
gtw66 is offline
post #2 of 8 (permalink) Old 12-15-2011, 04:18 PM
For a specific cylinder misfire, I would pull the plug and check it, as well as ohm the plug wire. Wait, on 2000 you likely have COP and no wires. If that is the case maybe one coil if the plug is OK. In addition, maybe fuel injector connection for that one cylinder.
For EGR others have posted to remove the vacuum line to the EGR valve. Idle the engine, put a hose on the diaphragm and suck on it. It should hold a vacuum and kill the engine or at lease make it idle really rough.
And a side note. New plugs are not necessarily better than the old ones. Bad quality comes in all brands. I posted a pic recently in the gereral discussion about Autolite with a picture, two differene kinds of plugs with the same number, and one misassembled with a long ceramic. I returned them. Ford brand may be better quality, maybe not.
post #3 of 8 (permalink) Old 12-15-2011, 08:37 PM
Trader Score: 7 reviews
Surprised to read that you did not replace the lower intake gasket. That has been known to leak in unmetered air with age. Could be the cause of your vacuum leak.
--Nick
bull geek is offline
post #4 of 8 (permalink) Old 12-15-2011, 09:03 PM
^+1. 2000 tec is cop (coil on plug). I vote for a new #1 coil and boot for the po301 flashing misfire code. Then, clear all codes. If po171/174 lean codes reappear, suspect lim gasket. Also, swap out that dpfe. When faulty, they have a tendency to display a myriad of unrelated codes. I recommend the borg-warner dpfe from advance auto or oreilly. Part#egr631 or #egr155 depending on the style your 2000 tec has (build date).
post #5 of 8 (permalink) Old 01-11-2012, 11:24 PM
Wow, I'm having some of the same probs with my 2000 Vulcan. I'm getting P0171, P0113, P0122, and P0301 and the dreaded rough idle. I've seafoamed it, changed the plugs, and cleaned the MAF but no improvement. I've tap tested my IAC (good) and I've spray tested for vac leaks to no avail. I'm at my wits end now and I don't trust shops. Don't think coil pack needs to be changed out. ~15.5 Kohms between towers and ~2.3 ohms between pins. I'm praying it comes to me in my sleep or something. I'll post what I find. How's your heating / cooling? Any issues there? My condenser's on the blink and my temp gauge takes long to get up to normal. Never fully warms up on my short drives. Flushed system / heater core - heat's good. Electrical is floating around the outer edges of my mind....Good luck with yours.
ismith is offline
post #6 of 8 (permalink) Old 01-11-2012, 11:41 PM
76tiger's Avatar
I have replaced three of coil on plugs on my 2000 SEL in the last three years because of misfires.
Easy way to find out is to move the coil from 1 to say 4. If the code moves to the other spot, you found the problem. And you can get to plug 4 just a bit faster.
76tiger is offline
post #7 of 8 (permalink) Old 01-12-2012, 07:39 AM
repairman54's Avatar
2X
Moving the coil to another cylinder is a quick and easy check with the COP. I just had my #2 go bad on New Years day BTW, it was my 2nd COP to go in 203k miles.
Misfire is the first thing to fix, then see what other codes pop up after that.
John
'11 Tahoe
'09 Malilbu LS
'03 Sable LS 24v
'05 Sable 24v son's
'01 FLHR
Ski Doo's Sea Doo
Previously enjoyed vehicles
'07 Mustang GT 3 pedals
'89 S10 Blazer 4x4
'75 Cordoba
'68 GTO
'68 Chrysler Newport 2dr
'67 Chevy Caprice 2dr
'67 Chevelle
'65 Bonneville
'65 Chevelle
'64 Olds Jetstar 88
repairman54 is offline
post #8 of 8 (permalink) Old 01-12-2012, 08:50 PM
The rubber elbow that connects the metal tube coming up from the PVC valve to the underside of the throttle body deteriorates and gets a crack in it. This is a common reason for the P0171, P0174 codes.
rabbitdog is offline
