Broken PCV elbow hose HELP! - Taurus Car Club of America : Ford Taurus Forum
post #1 of 4 (permalink) Old 06-14-2011, 12:02 AM Thread Starter
ortizj212's Avatar
Hey folks, So I've seen online that this is a common issue with the taurus!
SAMPLE OF THE EXACT PCV ELBOW I HAVE
The top portion of that part is broken and I have a misfire (might be unrelated), loss of power and some above average vibrations on idle.
Now I bought the car like this a few months back, But I realized this pcv elbow recently, the check engine codes indicate a misfire on cylinder #4 and below threshold efficiency on the catalytic converter.
My questions
-May the broken elbow be related to the symptoms mentioned?
-I read there's a revised, ribbed version available, however online for sale I only find the exact same version of the faulty one that I have (like the ebay link) anyone know the model or a link to purchase the newer one?
Thanks!
ortizj212 is offline
post #2 of 4 (permalink) Old 06-14-2011, 07:37 AM
The PCV hose is a vacuum leak, and will cause lots of problems, including missfires. Missfires can and will damage the cat. Fix the known problem, reset the PCM (disconnect batt for 10 minutes), drive it for a few days / 100+ miles, and see what codes return. Hopefully the missfire didnt damage the cat.
post #3 of 4 (permalink) Old 06-14-2011, 07:49 AM
PCV ell
My questions
Thanks!
Pic of revised ell and attached line that goes to the PCV valve.
Available at RockAuto for about $13.50 + S&L. Vacuum leaks do not effect all cylinders equally, and make the engine run lean, mostly at idle and low speeds.
PCV valve replacement is quite important. If that sticks, it makes the engine run the opposite of a leak, and the exhaust that bypasses the rings into the crankcase with it's water, mostly stays in the oil. SLUDGE.
post #4 of 4 (permalink) Old 04-03-2015, 06:16 AM
Well you've got the DOHC engine. I'd try your Vin # here. I'd replace the valve, hose, and elbow at once if it's not much more.
FordParts.com
For anyone with the 2001 Taurus SES Vin 2 (8th digit)- flex fuel vulcan engine the hose comes with the pcv valve itself. It took me a while to figure out that the hose comes with the valve. Thus, why my searches kept coming up empty. From what I could see, the non-OEM valves don't come with the hose.
This part number from the ford parts website will get the elbow, valve, and hose as one unit around 23 buck. The grommet can be bought separately, but I haven't tried to replace mine yet.
Part Number
6C324
Ford
Crankcase Vent Hose And Connector
3.0 12V; Incl. 6A666 P.C.V.,hose & 6762 connector
c0ke543 is offline
