2003 Ford Taurus SES fuel pressure regulator - Taurus Car Club of America : Ford Taurus Forum
post #1 of 9 (permalink) Old 05-16-2011, 10:18 AM Thread Starter
Car lurches at 60+ mph. Rpm goes from 20 to 30rpm.
Suspect defective fuel pressure regulator or vacuum line. This does not occur at laower or idle speeds.
Any suggestions welcomed.
Freddy is offline
post #2 of 9 (permalink) Old 05-16-2011, 10:33 AM
The FPR is electronic, and works along with the FDM in the trunk to adjust pump speed to control pressure. Use a scan tool that wil lread the fuel pressure PID to see what the FP is to eliminate the FPR as the problem, which I doubt it is.
Do you mean goes from 2000 to 3000 RPM?? If so, sounds like they tranny is downshifting from OD to 3 for no reason. Suspect a failing VSS>
Jeff K is online now
post #3 of 9 (permalink) Old 05-16-2011, 12:53 PM Thread Starter
ford taurus vss
I am not sure what you mean by VSS?
Please elaborate.
Freddy is offline
post #4 of 9 (permalink) Old 05-16-2011, 03:58 PM
VSS = Vehicle speed sensor, also known as OSS = Output speed sensor. Tells PCM the cars speed. Located in the pass side of tranny. Known Taurus problem that causes all kinds of tranny shift and slipping issues.
post #5 of 9 (permalink) Old 05-16-2011, 04:36 PM
00greenlx's Avatar
Jeff nailed it! The VSS is probably what is causing this.
I just noticed on a trip this weekend as I went over road dots that my speedometer went all wacky for a second and my transmission did NOT like it. Now i'll have to replace my VSS. That or check the connection and see if it needs cleaning, at that point why not just replace it ?
Engine: 3.0L FFV Vulcan (2v)
Transmission: AX4S / AXOD
00greenlx is offline
post #6 of 9 (permalink) Old 05-16-2011, 05:28 PM Thread Starter
2003 Ford taurus SES, VSS TSS, OSS
VSS - Variable Speed Sensor
OSS - Output Shaft Speed Sensor
TSS -- TRANSMISSION SHIFTING SOLENOID
I assume that the
VSS, TSS and OSS are the same?
Where are they located on a 2003 Ford taurus 6 cylinder engine?
Wife drives car daily for 5 miles to Gym or grocery store.
The problem of lurching was evident when I began to climb a hill in January 2011. I had the car on Cruise Control (CC). Yesterday, I drove it again on Cruise Control and problem re-appeared. I took it off CC and it kept lurching until we arrived at home -- 13 miles.
Today, I took it to several shops but they were busy and suggested I come back tomorrow.
Problem did not appear while driving around town below 35 MPH.
Mechanic will test while driving tomorrow. He will conduct diagnostic tests.
Freddy is offline
post #7 of 9 (permalink) Old 05-16-2011, 05:36 PM Thread Starter
AUTOZONE Clerk SAYS THERE ARE 2 SENSORS -- INPUT SHAFT SPEED SENSOR AND
2. OUTPUT SPEED SENSOR. Any sketch showing location is appreciated.
Freddy is offline
post #8 of 9 (permalink) Old 05-16-2011, 07:04 PM
00greenlx's Avatar
Here, it's refered to as an OSS (Output Shaft Speed sensor)
See Attachment, Keep in mind you can get to this from the TOP ignore the directions that state to drop the y-pipe.
post #9 of 9 (permalink) Old 05-16-2011, 08:35 PM
Ford changed the name of the vss to oss in 2000. Both are the tranny output sensor. Tss (turbine shaft speed sensor) is the tranny input sensor.
