1999 Ford Taurus Wagon 3.0 DOHC Serpentine Belt Replacement - Taurus Car Club of America : Ford Taurus Forum
post #1 of 16 (permalink) Old 08-14-2010, 02:34 PM Thread Starter
190000Taurus's Avatar
Hello,
The last time my serpentine belt was replaced was at 58,000 miles and now I am at 217,000 miles. Hmm, better not wait until it fails.
I got the Motocraft belt and a serpentine tool w/15mm socket. My question is how do I properly remove the tension from the belt. Using the Chilton manual, it indicates I should put tool on the tensioner bolt and turn it counterclock-wise. When I do this, I was actually loosening a bolt which I quickly re-tighten. Without a diagram, I was blinding placing the tool onto the tensioner pulley at whatever bolt I could find. What am I doing wrong?
Does anyone have a diagram of where eactly I am supposed to place the tool?
I will try again Sunday morning when I have more information.
Thanks for all your help!
Doug
190000Taurus is offline
post #2 of 16 (permalink) Old 08-15-2010, 08:43 AM
don2775's Avatar
Just put the tool on the tensioner bolt...,don't turn the bolt, PUSH... the tensioner bolt counterclockwise to loosen the tensioner, it is spring loaded,you can then just remove the old belt and feed the new belt through the pulleys..(there is a diagram of how to feed the belt thru which pulleys on the underside of the hood ).
After you have fed the belt thru you can just push the tensioner away and put the belt back on the tensioner pulley.
don2775 is offline
post #3 of 16 (permalink) Old 08-15-2010, 05:43 PM Thread Starter
Successful at last but how how tight should be the pulley idler?
Hi everybody,
Well, after having greased up hands and elbows I finally got the belt on this Sunday afternoon There are three things I want to bring to attention.
1) The biggest issue was turning the tensioner in the counterclockwise direction according to the Chilton Manual. It should be clockwise direction.
2) I discovered, on the tensioner arm there is a notch for a 3/8 break bar and that worked as well too.
3) Turning or pushing the tensioner pulley bolt would have worked if I knew it was clockwise direction.
My next question is originally, I accidently loosed the tensioner pulley bolt by turning it counterclockwise. It appeared to not be too tight in the first place and it was easy to turn. How tight should it be? Should I torque it? I don't want the pulley idler to come loose while I am driving or it being too tight causing failure of the bearing assembly. Mind it, this is the original factory tensioner assembly with 217,000 miles on it.
Thanks again all,
Doug
post #4 of 16 (permalink) Old 08-15-2010, 06:00 PM
wjc
wjc's Avatar
Originally Posted by 190000Taurus View Post
Hi everybody,
Thanks again all,
Doug
Hand tight is fine, it won't loosen up while driving. if I remember correctly the Vulcan and Duratec bolts are reversed, so the manual probably only included directions for the Vulcan. Pretty much with any tensioner pulley bolt, the "loosening" direction is the wrong way.
wjc is offline
post #5 of 16 (permalink) Old 08-15-2010, 10:15 PM
danhasenauer's Avatar
Just use ( German spec) "Gutentite" by hand and you'll be fine!
'96 LX DOHC Moonlight Blue
RIP 'Ol Blue - 09/2012
danhasenauer is offline
post #6 of 16 (permalink) Old 08-28-2010, 04:27 PM
I always wondering if this was German for good and tight.
2000 Taurus SEL - 24v DOHC Duratec
kjm-taurus is offline
post #7 of 16 (permalink) Old 01-29-2011, 01:17 PM
Nein, das is falsch.
"Gutentite" is an Americanism making fun of the real German greeting "guten tag" meaning 'good day' (we would say "hello"). A German might say "gut und dicht" or "gut und sicher" (but not "sicherdicht").
u090061 is offline
post #8 of 16 (permalink) Old 01-30-2011, 11:46 PM
I made that same mistake when changing my DOHC Serpentine belt. I was following the Haynes manual though, which either said the wrong direction or was confusing for some reason (can't remember).
Anyway, when my bolt started loosening, I just tightened it back up. I never had any problem with it. Once it's tight enough, it just starts turning the tensioner anyway.
steelstr45 is offline
post #9 of 16 (permalink) Old 01-31-2011, 12:56 PM
Cake monster
You can figure out which direction the tensioner should go by looking at the belt routing and moving it in the direction that would remove tension.
JW657 is offline
post #10 of 16 (permalink) Old 01-31-2011, 01:25 PM
^ Both haynes and chiltons have it backasswards.
