2000 Ford Taurus Steering Noise - Taurus Car Club of America : Ford Taurus Forum
post #1 of 9 (permalink) Old 06-03-2010, 09:03 PM Thread Starter
I have a 2000 Ford Taurus SES sedan, DOHC 24V, with 132k miles on it. I love it but I realize Im on borrowed time but I dont want to give it up. Recently when turning my steering wheel, I started hearing a bit of screeching. Now, 2 weeks later, its very loud and screeching every time I turn the steering wheel just a little bit. This is especially true when parking or slowly turning. Is this a Power steering Pump issue? Ive made sure to get all the necessary tune ups but this is a new sound. Its embarrassing and I feel like its just going to stop steering altogether at some point. My power steering fluid is fine and Ive filled it and it stays filled. Any ideas or price range to get it fixed??
Thanks!
jamor is offline
post #2 of 9 (permalink) Old 06-03-2010, 09:07 PM
sadistic's Avatar
QUOTE (jamor @ Jun 3 2010, 09:03 PM)
Thanks![/b]
when i replace my ps pump it said not to hold in the furthest position for more then a few seconds either left or right. or a damaged ps pump will result. mite have burned it up? this was when bleeding the air out just thought i would mention it.
sadistic is offline
post #3 of 9 (permalink) Old 06-03-2010, 09:12 PM Thread Starter
QUOTE (sadistic @ Jun 3 2010, 10:07 PM)
Thanks![/b]
Thanks! I appreciate the response! I kinda think it might be but Ive seen in other posts about ball joints and tie rods.
jamor is offline
post #4 of 9 (permalink) Old 06-03-2010, 09:19 PM
sadistic's Avatar
QUOTE (jamor @ Jun 3 2010, 09:12 PM)
Thanks![/b]
could be a wheel bearing to that has gone bad just to mention
sadistic is offline
post #5 of 9 (permalink) Old 06-03-2010, 11:08 PM Thread Starter
QUOTE (sadistic @ Jun 3 2010, 10:19 PM)
Thanks![/b]
Thanks a lot! I will keep that in mind. I appreciate it.
jamor is offline
post #6 of 9 (permalink) Old 06-04-2010, 01:16 AM
QUOTE (jamor @ Jun 3 2010, 11:08 PM)
Thanks![/b]
Sounds like a belt to me.
kgrantkey is offline
post #7 of 9 (permalink) Old 06-04-2010, 03:09 AM
Thanks![/b]
You are not on borrowed time if you treated your bull well.
hhu168 is offline
post #8 of 9 (permalink) Old 06-04-2010, 03:43 AM
Thanks![/b]
Have an acquaintance replicate the sound whilst in park with the hood open. Spray belt conditioner, or water, on the accessory belt. If this affects or temporarily eliminates the noise, it is likely that your accessory belt is worn out and requires replacement. There is also the possibility that the tensioner pulley is not creating enough force to retain the belt on the accessory assembly. There is yet another possibility that the power steering pump is faulty, but it should not be considered until the two easier options are reviewed.
scalyblue is offline
post #9 of 9 (permalink) Old 06-04-2010, 09:20 AM
The most likely cause of the rubbery sounding squeak while turning, in parking lots etc., is the upper strut mount bearing failure. When the bearing fails the spring tries to slide along the rubber spring isolator and it makes a squeaking sound. Spray some soapy water up to the top of the struts to see if it quiets the noise. If it does, you can change just the mount or you can use quick struts.
Good luck, Popeye
Popeye is offline
