No Start, Neutral Park Switch? 1986 Lx - Taurus Car Club of America : Ford Taurus Forum
post #1 of 10 (permalink) Old 04-28-2010, 12:44 AM Thread Starter
kpeters's Avatar
Send a message via MSN to kpeters
Hey guys my Taurus started giving me some problems that it wouldn't start on certain positions now it doesn't start at all. Im guessing it's the neutral switch take your guesses please.
It's a 3.0 vulcan LX. 1986.
Cheers!
Vid:
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/Xln6ifht_5Q"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/Xln6ifht_5Q" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
Tried to attach the vid but looks like im a dork here is the link http://www.youtube.com/watch?v=Xln6ifht_5Q
1986 Ford Taurus LX resto project
kpeters is offline
post #2 of 10 (permalink) Old 04-28-2010, 08:07 AM
Trader Score: 7 reviews
Considering how sensitive later model Tauruses are to battery voltage, I wonder if the same applies here. What kind of readings does your battery have right now?
--Nick
bull geek is offline
post #3 of 10 (permalink) Old 04-28-2010, 09:10 AM
jw89sho's Avatar
You can also check the switch and it&#39;s alignment.
Hold brakes, put car in low or (1) and try to start. Repeat for each position going up. Car should only start in (P) or (N). If it starts anywhere else, switch needs service. You can also jump the battery lead to the small terminal and see if it starts.
Solenoid could have failed. Pull small wire and check for voltage when turned to start.
Nice thing about an old Ford...screwdriver across the big terminals will start it. Don&#39;t be afraid of the sparks.
Josh
jw89sho is offline
post #4 of 10 (permalink) Old 04-28-2010, 09:11 AM
Adding Youtube Vids:
In Advanced (full) Edit mode: Click [Insert: youtube]
take the Youtube URL and paste in everything AFTER the &#39;=&#39; sign.
http : // www . youtube.com / watch?v = Xln6ifht_5Q
It was nice of them to put the solenoid right on the fender. Pitty they took it away, and placed it on the starter motor.
2003 Vulcan AX4S – Spruce Green
For Sale
Sign-up for a free account.
Vehicle Maintenance Log.
Also has an Android App.
thesavo is offline
post #5 of 10 (permalink) Old 04-28-2010, 10:30 AM Thread Starter
kpeters's Avatar
Hey guys thanks for all the feedback! Tried to do the alignment thing on the neutral switch by getting it on Neutral position and inserting a clip on the little hole while adjusting the position but that didn&#39;t work out.
What happens if I try to start the car on L or D and it does crank? Will it damage the gearbox? I&#39;ve always wondered what can happen because I was tempted to do that but scared it would give me some costly problems.
I was looking for the starter motor but couldn&#39;t find it easily (had bad lighting at the time) but I recall it was on the firewall side of the engine...So just jumping the two big connectors should start the car?
And by the small terminal you mean the one on the starter relay thing on the fender or on the starter itself?
Sorry for all questions and thanks for all the help including the youtube help
kpeters is offline
post #6 of 10 (permalink) Old 04-28-2010, 12:29 PM
dark_fire's Avatar
If you have your foot firmly on the brake, nothing should happen other than a little lurch.
<div class='quotetop'>QUOTE
dark_fire is offline
post #7 of 10 (permalink) Old 04-28-2010, 01:31 PM Thread Starter
kpeters's Avatar
QUOTE (dark_fire @ Apr 28 2010, 10:29 AM)
If you have your foot firmly on the brake, nothing should happen other than a little lurch.[/b]
Thanks man! It&#39;s the only automatic I&#39;ve ever had so no experience on those sort of things.
kpeters is offline
post #8 of 10 (permalink) Old 04-29-2010, 10:09 AM
jw89sho's Avatar
QUOTE (Kpeters @ Apr 28 2010, 09:30 AM)
...I was looking for the starter motor but couldn&#39;t find it easily (had bad lighting at the time) but I recall it was on the firewall side of the engine...So just jumping the two big connectors should start the car?
And by the small terminal you mean the one on the starter relay thing on the fender or on the starter itself?....[/b]
Starter is hanging out front and center, right behind radiator, next to oil filter. The relay for testing is on the driver&#39;s fender, the small terminal is on top of the relay. There is no small wire going to the starter, just the big one from the relay.
Josh
jw89sho is offline
post #9 of 10 (permalink) Old 04-29-2010, 11:02 AM Thread Starter
kpeters's Avatar
QUOTE (jw89sho @ Apr 29 2010, 08:09 AM)
Thanks for the explanation lets see if i get it right... So a wire from the uppermost terminal On the relay jumping to the positive post Of the battery should turn the starter? Or an i gonna start a fire
kpeters is offline
post #10 of 10 (permalink) Old 04-29-2010, 01:52 PM Thread Starter
kpeters's Avatar
BTW just wanna say thanks to all of you the problem is the neutral safety switch, following your recommendations what I did was to jump the upper terminal with the positive side of the battery and the starter cranked. Later I checked on the service manual and it said that if it did crank then my neutral switch was damaged.
I managed to start the engine this way and give it a spin! Was real nice only very WEIRD thing was that when I disconnected the small terminal i got the SPEED message on the electronic cluster and it wouldn&#39;t go away until I connected back the cable.
kpeters is offline
