Front Door Panel Removal - 99 Taurus. - Taurus Car Club of America : Ford Taurus Forum
Closed Thread
post #1 of 14 (permalink) Old 04-10-2010, 10:05 PM Thread Starter
can someone link me to a how-to with pictures on how to remove the passenger-side door panel? i need to replace a mirror. i did a search and came up with nothing concrete. thanks for you time!
d.v. is offline
post #2 of 14 (permalink) Old 04-10-2010, 10:13 PM
choikzilla's Avatar
Send a message via AIM to choikzilla Send a message via Yahoo to choikzilla
I dont have pics... but I just did it on my 99 to put in sail panel speakers. Mine had 3 phillips head screws on the outside edges of the door panel. Remove those. Then with a tiny flathead screwdriver remove the little panel behind the door handle. If you dont remove that it'll break when u take the panel off (I should know lol). There is another screw in the hole where your hand goes to close the door. Then with a bigger flathead just slide it in between the door panel and the door and gently pry out along the panel. Once its all off just pull the panel up over the pop up lock and disconnect all the harnesses. To get the mirror pop out the sail panel by using the small flathead to take out the middle where the speaker is... theres a 6mm bolt behind it... with another one visable once the door panel is off. Unfortunatly, thats all i know as I didn't have to remove the mirror. Hope that helps! Good Luck!
1999 Taurus SE 153k miles bought 2/5/2010
choikzilla is offline
post #3 of 14 (permalink) Old 04-11-2010, 04:48 AM
fonicsmonkey's Avatar
Remove the cover from behind the inside door handle by gently pulling it out to release the retaining tabs
Remove the pull cup retaining screw cover and...
... remove the retaining screw from the cup and lift the cup straight up out of the door panel
Remove the two sail panel/speaker grille retaining screws and...
... remove the panel/grille from the door
The door panel is retained to the door by 11 retaining clips
Carefully lift the door panel off of the door and...
... detach the electrical connectors from the switches and remove the panel from the vehicle
fonicsmonkey is offline
post #4 of 14 (permalink) Old 04-11-2010, 03:35 PM
choikzilla's Avatar
I didnt have those 2 screws on the sail panel... mine were under and inside it. Maybe cause it's a 99.... Either way it's easy lol
post #5 of 14 (permalink) Old 04-11-2010, 03:40 PM
QUOTE (Choikzilla @ Apr 11 2010, 02:35 PM)
I didnt have those 2 screws on the sail panel... mine were under and inside it. Maybe cause it's a 99.... Either way it's easy lol[/b]
I got the info from Chiltons Online...Sometimes its a little off...but generally gets you pointed in the right direction...I believe Autozone repair info uses Chiltons library.
post #6 of 14 (permalink) Old 04-13-2010, 10:36 AM Thread Starter
thanks everyone, easy off it was!
d.v. is offline
post #7 of 14 (permalink) Old 04-18-2011, 04:47 PM
Could someone re-link the pictures? They're dead links now.
cpusavant is offline
post #8 of 14 (permalink) Old 04-18-2011, 08:14 PM
Chilton and Haynes aren't worth the paper they are printed on.
jay144 is offline
post #9 of 14 (permalink) Old 03-15-2012, 11:52 AM
I dont agree. I got a Haynes manual for my 1994 ford taurus and before I started replacing most of my engine components, I read that manual alot and it helped me understand how to do everything. it was clear, informative, and accurate. I give a couple thumbs up to the Haynes manual.
Delawares Maverick
DanielTimbs is offline
post #10 of 14 (permalink) Old 03-15-2012, 12:12 PM
danhasenauer's Avatar
Trim Panel, Door
Front
Removal and Installation
1. Remove cover behind inside door handle.
2. Remove plug button from bottom of pull cup.
3. Remove screw retaining front door trim panel.
4. Starting at bottom of trim panel, carefully remove door panel by pulling away from door.
5. Disconnect electrical connectors as necessary.
6. To install, reverse Removal procedure. Tighten door panel retaining screw to 1.4-2.0 N-m (12-18 lb-in).
P.S. - Daniel, there is no such thing as a Taurus SOHC engine. You most likely mean the Vulcan single cam overhead valve (pushrod) engine.
'96 LX DOHC Moonlight Blue
RIP 'Ol Blue - 09/2012
danhasenauer is offline
Closed Thread
