Replacing Inner Tie Rod Ends, How Hard To Remove Boot, Any Tips? - Taurus Car Club of America : Ford Taurus Forum
post #1 of 6 (permalink) Old 03-26-2010, 09:03 PM Thread Starter
I am going to attempt to replace my inner tie rod ends. Any tips on safely removing the rack boots? How does the vent tube attach to the boots? Do I just pull the tube off? I wish I had new boots on hand just in case.
ALSO, do you need to hold the rack with a wrench when you loosen the tie rod ends? Thanks
clydesdale is offline
post #2 of 6 (permalink) Old 03-26-2010, 10:59 PM
jw89sho's Avatar
Boot is easy to remove, hard to get to. One spring clamp on the small end and a screw clamp on the big end. The tube just pushes into the boot. There's a tool available at AutoZone and other places for rental that makes removing the inner joint so much easier, it just slides over the rod and allows use of a rachet out by the wheel. I found surprisingly little torque on the joint. You may want/need to drop the rear of the subframe a little to get to it better. No tool necessary to hold the rack itself.
Josh
jw89sho is offline
post #3 of 6 (permalink) Old 03-27-2010, 11:31 AM Thread Starter
Are there any pins holding the inners in place or are they just screwed in?
QUOTE (jw89sho @ Mar 26 2010, 10:59 PM)
Boot is easy to remove, hard to get to. One spring clamp on the small end and a screw clamp on the big end. The tube just pushes into the boot. There's a tool available at AutoZone and other places for rental that makes removing the inner joint so much easier, it just slides over the rod and allows use of a rachet out by the wheel. I found surprisingly little torque on the joint. You may want/need to drop the rear of the subframe a little to get to it better. No tool necessary to hold the rack itself.[/b]
post #4 of 6 (permalink) Old 03-27-2010, 08:08 PM
jw89sho's Avatar
There is a shear pin on the original parts, may not be there if it's been serviced before. Put a little Loctite on the threads with the new parts.
Josh
jw89sho is offline
post #5 of 6 (permalink) Old 03-28-2010, 07:42 PM Thread Starter
The boots came off pretty easy. I held the rack with a wrench on the driver's side and they twisted out with the harbor freight tool. Mine were original and I did not notice a shear pin. I retorqued them and used the thread locker that came with the moog parts.
QUOTE (jw89sho @ Mar 27 2010, 08:08 PM)
There is a shear pin on the original parts, may not be there if it's been serviced before. Put a little Loctite on the threads with the new parts.[/b]
post #6 of 6 (permalink) Old 03-29-2010, 09:41 AM
mwt
mwt's Avatar
QUOTE (clydesdale @ Mar 28 2010, 06:42 PM)
The shear pins were only on the GenI and II
Mike
94gl Vulcan totalled 4-01-04
New Paint coming soon
2000 SES Duratec
mwt is offline
