P0171 & P0174 - Taurus Car Club of America : Ford Taurus Forum
post #1 of 15 (permalink) Old 02-28-2010, 01:30 AM Thread Starter
CEL on my 01 Sable was on yesterday and the reader pulls P0171 & P0174. Just did a through search, it seems a lot of people have the same problem and most of them fixed the problem by replacing UIM and LIM gasket. I did remove UIM before, so I know how to finish that part. However, last time I removed the UIM, I could not figure out how to LIM, which was my intent as well. I was puzzled by the fuel rails above LIM and am not sure how to handle them. Could somebody please lend a hand?
Also, annual inspection is due tomorrow. I am just wondering if I can pass the inspection by just removing the code. I tried to remove the code this afternoon. CEL went back on after 30 miles and 3 engine start-ups. I know I will fix this problem later, but just want to pass the inspection first and buy me some time to fix it later.
thanks
Sean
2001 Mercury Sable LS Premium
24V DOHC, 152K
batrachian is offline
post #2 of 15 (permalink) Old 02-28-2010, 03:47 AM
spridget's Avatar
The fuel rail and injectors do not need to be removed from the LIM to remove the LIM from the heads. You need a quick-disconnect tool to disconnect the fuel line from the fuel rail. The fuel rail may have a sensor and/or vacuum line that needs to be removed. Other than that, each bank on the LIM is held down by 4 8mm bolts. Remove all 8 and the LIM should come out as a unit with both halves held together by the fuel rail and injectors.
Inspect the PCV hose elbow. It will collapse and split. Very common source of these two simultaneous codes.
RIP TCCA
'96 ES SHO -
spridget is offline
post #3 of 15 (permalink) Old 02-28-2010, 10:09 AM
The PCV valve elbow is often the cause of these lean codes on a DOHC. Do this before you mess with the LIM and UIM gaskets. Because you have the code on both banks, it is likely that it&#39;s something that&#39;s letting extra air in before the LIM and UIM gaskets...
yiranhu is offline
post #4 of 15 (permalink) Old 03-02-2010, 04:54 PM Thread Starter
QUOTE (yiranhu @ Feb 28 2010, 11:09 AM)
The PCV valve elbow is often the cause of these lean codes on a DOHC. Do this before you mess with the LIM and UIM gaskets. Because you have the code on both banks, it is likely that it&#39;s something that&#39;s letting extra air in before the LIM and UIM gaskets...[/b]
The elbow hides so well under the UIM and I could not find a way to check it directly. While checking, I actually found the other hose next to the elbow off the UIM is cracked. Does anybody know what size it is and where can I buy a replacement?
Also, is there a way to check vaccum leak?
24V DOHC, 152K
post #5 of 15 (permalink) Old 03-02-2010, 08:13 PM
mwt
mwt's Avatar
Did you check the wiki?
Mike
94gl Vulcan totalled 4-01-04
New Paint coming soon
2000 SES Duratec
mwt is offline
post #6 of 15 (permalink) Old 03-02-2010, 09:39 PM Thread Starter
QUOTE (mwt @ Mar 2 2010, 09:13 PM)
Mike
Yes, wiki has the information about the pcv hose set including the elbow. But the hose I need to replace is the one next to the pcv elbow off the UIM shown in the picture below. Does anybody know what size it is and where I can find it?
24V DOHC, 152K
post #7 of 15 (permalink) Old 03-03-2010, 06:52 AM
spridget's Avatar
I&#39;d have to look at the entire piece of hose to be sure, but you can probably make your own with a piece of 3/8" rubber hose. It&#39;s a vacuum line, but I can&#39;t remember where it runs.
RIP TCCA
'96 ES SHO -
spridget is offline
post #8 of 15 (permalink) Old 03-03-2010, 08:09 AM
Mine is a vulcan and I replaced the PCV elbow yesterday ( after reading several threads here about P0174 code) andr dealing with rough idle/ code P0174 for a couple of months. I would definately check this out next.
Good Luck!
B
Bob2001se is offline
post #9 of 15 (permalink) Old 03-03-2010, 09:02 AM
For what it&#39;s worth, I spent about a year messing around with codes P0171/P0174 and various parts for my 2004 wagon; codes just kept coming back and it ran very rough on startup on cold days for a few minutes. Finally I took it to someone who ran what is called a smoke test and that clearly showed a hole in the upper intake manifold and a leak around the IAC gasket. Fixed those and the code hasn&#39;t come back.
betsyr2 is offline
post #10 of 15 (permalink) Old 03-03-2010, 11:28 AM Thread Starter
Again, does anybody know what size this hose is? I ran over to the dealer and they could not figure it out either. Not becuase this is the only vehicle I have, I can take the hose off and take it to the dealer. Sigh.
24V DOHC, 152K
