Where A 1990 Ford Taurus 3.8l Engine Number Located? - Taurus Car Club of America : Ford Taurus Forum
post #1 of 11 (permalink) Old 02-11-2010, 11:15 AM Thread Starter
I'm from Ukraine! Can you tell where the 1990 Ford Taurus 3.8L engine number located? Can photo?
kolian is offline
post #2 of 11 (permalink) Old 02-11-2010, 11:25 AM
Stocker's Avatar
Are you looking for the engine serial number or the VIN that's supposed to be stamped on the block?
The engine serial number is on a label on the front valve cover (often obliterated or missing), on a label on the backside of the rear valve cover, and on a label on the transmission side of the front cylinder head. It'll be a 9-digit number broken up in threes (e.g. 450 100 544).
If it's the VIN stamping on the block, I've never found it on any Ford.
Stocker is offline
post #3 of 11 (permalink) Old 02-11-2010, 01:18 PM Thread Starter
QUOTE (Stocker @ Feb 11 2010, 11:25 AM)
If it's the VIN stamping on the block, I've never found it on any Ford.[/b]
I need a serial number engine.Vy would not be able to point to the figure where the number? (I have a 1990 Lincoln Continental 3.8 V6, Ford Taurus engine with the same.)[attachment=32274:HPIM3534.JPG]
kolian is offline
post #4 of 11 (permalink) Old 02-12-2010, 12:41 AM
Stocker's Avatar
Here's a picture showing the label on the front valve cover, right below the oil cap:
The label is in roughly the same spot on the rear valve cover (it will be on the driver's side of the engine of course, and below the PCV valve). You'll probably need a mirror to see it, if not have to remove the valve cover entirely.
I see on the picture of your engine that there's a sticker on the intake manifold that looks about the right size to be the serial number label. What does it say?
Stocker is offline
post #5 of 11 (permalink) Old 02-14-2010, 05:57 AM Thread Starter
If I understand you correctly, then the number should be here?? :[attachment=32301:HPIM3534.JPG]
kolian is offline
post #6 of 11 (permalink) Old 02-14-2010, 05:59 AM Thread Starter
QUOTE
I see on the picture of your engine that there's a sticker on the intake manifold that looks about the right size to be the serial number label. What does it say?[/b]
This is a common label motor oil.
kolian is offline
post #7 of 11 (permalink) Old 02-14-2010, 12:36 PM
Stocker's Avatar
QUOTE (kolian @ Feb 14 2010, 04:57 AM)
If I understand you correctly, then the number should be here??[/b]
Yes, that's right. I wish I had my spare set of heads and valve covers handy so I could get a good picture of it, but I don't.
Stocker is offline
post #8 of 11 (permalink) Old 02-14-2010, 12:47 PM
Send a message via AIM to StevenRosenow Send a message via MSN to StevenRosenow Send a message via Yahoo to StevenRosenow
On both '89 Taurii that I owned that had the dreaded 3.8L, I never was able to find any engine serial number label.
1996 Taurus GL - 264K miles and climbing. 3.0L Vulcan/AX4S automatic
1992 Ford Taurus SHO - 218K miles and climbing. 3.0L 24V DOHC/MTX manual.
1955 Kenworth-Pacific School Coach school bus. 73 pass. cap. Over 500K miles and climbing. GMC 401 cid V6 gas engine/5-spd. Fuller 6252 manual.
StevenRosenow is offline
post #9 of 11 (permalink) Old 07-24-2010, 05:37 AM Thread Starter
Who knows where is the engine number (block number), the engine Ford 3.8L V6?
kolian is offline
post #10 of 11 (permalink) Old 07-24-2010, 02:33 PM
Stocker's Avatar
Here are the three engine number locations:
Okay, they won't embed into the post. vBulletin sucks.
The first picture is the front valve cover, the second is the rear valve cover.
The third is on the front cylinder head, on the driver's side.
If these labels are missing or illegible, you don't have an engine serial number anymore.
Name:	232 serial number - front.jpg
ID:	60128   Click image for larger version
Name:	232 serial number - rear.jpg
ID:	60129   Click image for larger version
Name:	232 serial number - side.jpg
Stocker is offline
