Member Number: 25928
Hi all,
I was going through the OBD codes on my daughter's 1996 GL (3.0 12-valve). There is a code P0340 - camshaft position sensor. The car runs fine, so I'm confused how it could be bad. It has 143K miles on it, but no squeak or chirp from the synchronizer gear so I don't think I need to replace that. Should I replace only the sensor? I don't feel like replacing the synchro gear if it doesn't need it. Comments? Thanks, Jim |
Bump - How can the car run OK with a bad camshaft position sensor?
Member Number: 5295
Drives: 2005 Taurus SE
3.0L Vulcan
Rep Power: 16 ![]() |
Remove the cam sensor off of the synchronizer and check it for damage. If there is damage then the sensor and synchronizer needs to be replaced. The synchronizer drives the oil pump as well.
Was the SES light on when you were checking code(s)? The car will run all right without the input of the cam sensor, it will have harder starts and lack power as the fuel injectors revert to a default setting.
#4 (permalink) | |
Member Number: 8134
Drives: 2001 Ford Taurus SES
3.0 OHV - Vulcan Engine
Royal Blue - Paint Code: LA
QUOTE (jkm3093 @ Jan 26 2010, 10:53 AM)
I'm sitting at roughly the same as your car (143,000). I have yet to hear a chirp and I've had the car since 63,000 miles. They tend to squeak between 100,000 and 150,000. It's honestly best to order the Motorcraft part (from my reading and researching on here) or another quality brand. The Dorman's are not good (there is a sticky at the top of the page warning you of it). I would just replace the entire shaft if you are getting the code. Best to error on the $100 safe side than not supplying oil to your engine (from the oil pump which is driven by the Camshaft Position Sensor and Shaft). There are tons of write-ups on here on how to remove it and replace it without getting the 1st cylinder to TDC. ~matt |
Member Number: 25947
Hi,
Newbie here. I have an 03 Taurus. I had clutch and transmission work done two months ago. Everything has been fine, then all of a sudden two days ago my MIL light comes on. I went to Autozone and got the codes P0340 and P1336. Would any of these have anything to do with the tranny work or is it just something completely on its own? I have no problems with idling or power. Thanks, tony |
#6 (permalink) | |
Member Number: 8134
QUOTE (cynfan @ Jan 26 2010, 03:47 PM)
I'm sure you didn't mean to hijack the thread, but what you may want to do is replace the CPS and shaft (the entire unit). It is a good possibility that both codes are alerting you to the CPS and shaft are failing. http://taurusclub.com/forum/index.php?show...33&hl=P1336 Also, I doubt that these codes are due to the work you had done, unless wiring wasn't done right (some kind of ground issue). If these codes were thrown by the work done, it would not have taken 2 months. Those codes are thrown pretty quickly once issues arise with the CPS. I'm just guessing here but you probably have roughly 72,000-105,000 miles on your bull. It's legitimate for this part to go around then. Some, like me, just have it go later than others. |
#7 (permalink) | |
QUOTE (the_intimidator_02 @ Jan 26 2010, 12:36 PM)
The other OBD codes are related to the bank 1 O2 sensor. Is that the one by the radiator? Thanks again for the assistance. |
Member Number: 5295
3.0L Vulcan
^^^The oil pump is not at risk unless the chirp is really there and/or there is play in the synchronizer. Even if the chirping is there it does take a bit before the oil pump will fail, but none the less why take the chance. You do not need to remove the synchronizer unless there is damage, which is why I recommend removing the cam sensor. If there is no damage, I'd try clearing the code and see if it comes back then go from there.
#9 (permalink) | ||
QUOTE (ricer333 @ Jan 26 2010, 03:58 PM)
I'm sure you didn't mean to hijack the thread, but what you may want to do is replace the CPS and shaft (the entire unit). It is a good possibility that both codes are alerting you to the CPS and shaft are failing. http://taurusclub.com/forum/index.php?show...33&hl=P1336 Also, I doubt that these codes are due to the work you had done, unless wiring wasn't done right (some kind of ground issue). If these codes were thrown by the work done, it would not have taken 2 months. Those codes are thrown pretty quickly once issues arise with the CPS. I'm just guessing here but you probably have roughly 72,000-105,000 miles on your bull. It's legitimate for this part to go around then. Some, like me, just have it go later than others. [/b][/quote] ricer333, No, I didn't mean to hijack anything. I saw the p0340 in the first post and just thought I'd keep it going here... Thanks for the input, I'll have the CPS and shaft checked out. tm |
#10 (permalink) | |
QUOTE (the_intimidator_02 @ Jan 26 2010, 06:40 PM)
Also, The other OBD codes being thrown are related to the bank 1 O2 sensor. Is that the one by the radiator? I'll be replacing that as well to get the CEL to go off. |
