Water Outlet Hose Broken - Taurus Car Club of America : Ford Taurus Forum
post #1 of 11 (permalink) Old 01-07-2010, 06:56 AM Thread Starter
Jah
Thumbs down
I have a 2002 Taurus with a DOHC engine, but the tee the goes from the water outlet hose (part #1F1Z*8A521*B broke. It is a tee from the water outlet hose, to the lower radiator hose, and a small line that runs back to the coolant overflow tank. I went to the ford dealership and found out instead of being able to get this one tee, I have to buy the entire water outlet hose ($150)!
I've looked in two junk yards and this piece is gone from both. I was wondering if anyone knew a place that I could get this one tee from, or something that I could use as a tee for this? I was thinking about trying to find a heater hose tee that would fit and clamping it down, but I am unsure if that would work.
Can someone please give me some suggestions on this?
Jah is offline
post #2 of 11 (permalink) Old 01-07-2010, 09:27 AM
Don't Be Stupid
40.95 from Fast Parts Network
http://www.trademotion.com/partlocator/ind...playCatalogid=0
00tec-satx is offline
post #3 of 11 (permalink) Old 01-07-2010, 09:35 AM Thread Starter
Jah
Thanks! I'm just trying to look at it to see if it is the right piece... Is there a way to check the part number for the part you listed? I tried typing the part number into their search box but nothing comes up.
Also on there, it says 2000-2007, but the guy at the ford dealership said only this part from a 2001-2002 taurus dohc will fit.
Again, I appreciate the help (more than you know...) but I'm just trying to verify that it is the correct part. I sent them an e-mail asking for a picture of it, but I'm not counting on getting it anytime soon, if they do send one.
Jah is offline
post #4 of 11 (permalink) Old 01-07-2010, 09:48 AM
Don't Be Stupid
I'd email them. Torrie will make sure it's the part you need
You could also post a WTB ad here, some people go to the yard fairly regularly. I'd go grab you one, but there were no newer duratecs out there.
post #5 of 11 (permalink) Old 01-07-2010, 10:03 AM Thread Starter
Jah
QUOTE (00tec-saTX @ Jan 7 2010, 10:48 AM)
You could also post a WTB ad here, some people go to the yard fairly regularly. I'd go grab you one, but there were no newer duratecs out there.[/b]
I just got an e-mail from Torrie helping me make sure that it is the right part. (that was real quick...)
Thank you so much for your help, I was searching everywhere and couldn't find anything.
Jah is offline
post #6 of 11 (permalink) Old 01-13-2010, 08:15 AM Thread Starter
Jah
I just got the part that I needed yesterday, but can someone give me a little help as to how to remove the old one? I can probably get it if i remove the intake going to the part that covers the air filter, but I'm trying to see if its possible without removing that?
Jah is offline
post #7 of 11 (permalink) Old 01-13-2010, 11:51 AM
Don't Be Stupid
Can you post a pic, so I could get an idea?
I'm not to familiar with the setup on the newer cars.
post #8 of 11 (permalink) Old 01-13-2010, 02:47 PM
Here's the instruction on removing the bypass tube, which seems to be connected to the part you are replacing. It says you need to remove the air-cleaner assembly. The air cleaner assembly is not hard to remove so just do it to save the trouble. The engine bay is so cramped that I remove the air-cleaner tube almost everytime I do anything.
yiranhu is offline
post #9 of 11 (permalink) Old 01-14-2010, 02:02 PM Thread Starter
Jah
Thanks! It was only connected by hose clamps, but I wanted to make sure before I started pulling on it and something breaks... But I got it off pretty easily. Now to find a way to get it back on... my hose clamp pliers don't seem to want to fit in these small areas...
Hopefully I can find something to just tie it open, slide everything in place, and cut the string to clamp the hoses down...
Jah is offline
post #10 of 11 (permalink) Old 01-14-2010, 02:15 PM
Don't Be Stupid
I replaced all those clamps with regular hose clamps to make it easier.
