Vss Stuck In Transmission - Taurus Car Club of America : Ford Taurus Forum
Old 10-29-2009, 09:19 PM   #1 (permalink)
Member Number: 23416
highweeds has a little shameless behaviour in the past
tried to replace vss in a 1998 Sable,vss mounted on lower part of trans passenger side close to exhaust,broke black plastic top piece off,body of vss seems to be siezed in transmission.Have sprayed lubed body of vss(wd-40 used not a high quality lube) very hard to get too.Any thoughts or tricks how to remove
highweeds is offline   Reply With Quote
Old 10-30-2009, 08:56 AM   #2 (permalink)
Member Number: 20769
Popeye has a little shameless behaviour in the past
The unit is designed as a " slip " fit. If you can get pliers around the base to rotate it enough to break it loose you can use a screw driver into the notch where the hold-down locks into you should be able to pop it out.
Good luck, Popeye
Popeye is offline   Reply With Quote
Old 10-30-2009, 12:54 PM   #3 (permalink)
mt_goat's Avatar
Member Number: 8675
mt_goat has a little shameless behaviour in the past
Here's what mine (95) looked like if that helps any:
Dale
mt_goat is offline   Reply With Quote
Old 11-01-2009, 10:42 AM   #4 (permalink)
Thanks for the help,I'm going to fabricate a tool (socket like) to rotate sensor.
Thanks again
Old 11-01-2009, 04:13 PM   #5 (permalink)
QUOTE (highweeds @ Nov 1 2009, 12:42 PM)
Thanks again[/b]
A 1 3/16" socket taps onto VSS nicely.Repaired.
Old 06-24-2010, 06:11 PM   #6 (permalink)
Member Number: 29906
Drives: 1996 Ford Taurus 3.0 Litre auto
issakar is an unknown quantity at this point
is that a 13/16" or a 1 and 3/16"?
issakar is offline   Reply With Quote
