03 Taurus Slight Steering Wheel Shake - Taurus Car Club of America : Ford Taurus Forum
post #1 of 8 (permalink) Old 10-06-2009, 10:10 PM Thread Starter
I have a 2003 taurus, and I have been trying to figure out what is causing a slight shake over 65mph. The shake was there ever since I got the car. Around 15k ago, I installed new shocks along with firestone tires. Now the car has around 75k miles. I have checked the entire front end. Ball joints are good, Tie rod ends and rack are in great shape. I rechecked the balance on the tires and they are all balanced and no bent wheels. Brake rotors are not warped.
The only thing I can think of is that there may be too much toe in. Also the camber is slightly out, I just rotated the tires and noticed wear on the the inside of the front tires. But usually camber doesnt cause any sort of shake.
I also drove another taurus of similar year, and it also had a shake. Is it just something these have? Any suggestions?
mopar318 is offline
post #2 of 8 (permalink) Old 10-06-2009, 10:13 PM
QUOTE (Mopar318 @ Oct 6 2009, 10:10 PM)
I also drove another taurus of similar year, and it also had a shake. Is it just something these have? Any suggestions?[/b]
First rotate the wheels. Bad tires or something can cause this type of problems. Then alignment.
yiranhu is offline
post #3 of 8 (permalink) Old 10-06-2009, 10:25 PM Thread Starter
QUOTE (yiranhu @ Oct 6 2009, 09:13 PM)
Read above. Shake has been there since I got the car. New tires didnt help. They are very good tires. I just rotated them over the weekend. No change.
mopar318 is offline
post #4 of 8 (permalink) Old 10-06-2009, 10:56 PM
Bent Rim?
2003 Vulcan AX4S Spruce Green
For Sale
Sign-up for a free account.
Vehicle Maintenance Log.
Also has an Android App.
thesavo is offline
post #5 of 8 (permalink) Old 10-07-2009, 10:04 AM
had same problem with my 03 taurus took it to goodyear they said 2 bent rims what they did was balance all 4 tires and put 2 bad rims on rear made a big difference on highway much less shaking on highway PS these cars are not very good highway cars i saw somewhere on net try not to exceed 60 mph if possible also since you have been rotating tires alot have it aligned again good luck
gary 55 is offline
post #6 of 8 (permalink) Old 10-07-2009, 01:13 PM
QUOTE (thesavo @ Oct 6 2009, 09:56 PM)
Bent Rim?[/b]
That would be my guess also.
Jeff K is online now
post #7 of 8 (permalink) Old 10-07-2009, 02:41 PM
Two Stooges's Avatar
QUOTE (gary55 @ Oct 7 2009, 06:04 AM)
...these cars are not very good highway cars i saw somewhere on net try not to exceed 60 mph if possible...[/b]
Have to disgree with that. My 2000 still cruises down the freeway at 100mph smooth as silk.
Two Stooges is offline
post #8 of 8 (permalink) Old 10-07-2009, 08:31 PM
kmohr3's Avatar
Send a message via AIM to kmohr3
Actually, if you have wear on the inside of the tires, they are probably toed-out (negative toe). I would have the alignment corrected and then you might try.......
On-vehicle spin-balance. This will balance the wheel, tire, rotor, bearing hub, etc. You might have to shop around for someone with the equipment to do this. Also, if this works you would probably want to mark the wheel location to the hub when removing the wheels/tires so you get them back on the same way.
ASE Master Tech
Registered Master Tech w/ VWoA
kmohr3 is offline
