Oil Level - Taurus Car Club of America : Ford Taurus Forum
post #1 of 28 (permalink) Old 09-04-2009, 01:28 PM Thread Starter
Newbie here.......
I have noticed when I check my oil level when it's cold it's on the full line but if I check it when it's hot it shows about a quart too much. Is this normal and should I take some out?
printmanjackson is offline
post #2 of 28 (permalink) Old 09-04-2009, 01:36 PM
Stick with the cold reading. After the engine has been running, oil can splash higher up in the dipstick tube before draining back down. If you're getting the correct amount on a cold reading then you're fine.
93_Taurus is offline
post #3 of 28 (permalink) Old 09-04-2009, 01:40 PM Thread Starter
How much oil do these Vulcan V6 engines hold?
post #4 of 28 (permalink) Old 09-04-2009, 02:28 PM
2000sable's Avatar
Thumbs down
QUOTE (printmanjackson @ Sep 4 2009, 01:40 PM)
How much oil do these Vulcan V6 engines hold?[/b]
Depends on the year or even what generation the car is...
Her name is Laura.
2000sable is offline
post #5 of 28 (permalink) Old 09-04-2009, 03:07 PM
ford_ses's Avatar
Vulcans are all the same capacity regardless. It's listed as 4.5 quarts, which is almost right in the middle of the crosshatch area. I've always just put in the whole five-quart jug, which puts it a hair below max.
Jim S. - Pittsburgh, PA
Past:
ford_ses is offline
post #6 of 28 (permalink) Old 09-04-2009, 04:37 PM
no you never read oil while engine is cold
does your engine run cold....NO...
always get a reading while engine is hot
Striker32 is offline
post #7 of 28 (permalink) Old 09-05-2009, 12:02 AM
QUOTE (Striker @ Sep 4 2009, 04:37 PM)
always get a reading while engine is hot[/b]
You sir, have absolutely no idea what you're talking about.
post #8 of 28 (permalink) Old 09-05-2009, 02:26 AM
94clit's Avatar
Go outside, run engine for a couple mins, shut off, wait a few seconds, check oil. put to max. done.
i would like to personally thank volvo!
94clit is offline
post #9 of 28 (permalink) Old 09-05-2009, 02:31 AM
You guys are either on crack or just enjoy spreading false inaccurate information.
post #10 of 28 (permalink) Old 09-05-2009, 03:06 AM
qwertz9586's Avatar
Doesn't matter if it's cold or hot, the dipstick has the marks for both. If it's cold, then it needs to be above the lowest mark in the crosshatch. If it's hot, it has to be below the highest mark. As long as the oil level is in the crosshatch then it's fine.
I normally check it hot. Pull up to get gas, turn off the engine, pay at the pump, start pumping gas, and go check the engine oil.
qwertz9586 is offline
