Transmission Fluid Capacity - Taurus Car Club of America : Ford Taurus Forum
post #1 of 6 (permalink) Old 06-05-2009, 10:46 PM Thread Starter
How much tranny fluid is needed to do a filter change. 01 Vulcan Sable
2000 Odyssey EX
1996 Acura GSR
1990 Itasca 27RT 454 TBI BBC
supra24valve is offline
post #2 of 6 (permalink) Old 06-06-2009, 12:03 AM
fonicsmonkey's Avatar
About 7-8 quarts
fonicsmonkey is offline
post #3 of 6 (permalink) Old 06-06-2009, 05:18 AM
fdogg96's Avatar
QUOTE (fonicsmonkey @ Jun 5 2009, 09:03 PM)
About 7-8 quarts[/b]
...of Mercon V.
1993 V6 3.2L SHO
Clubs: SHOCAL & SHOForum
fdogg96 is offline
post #4 of 6 (permalink) Old 06-06-2009, 06:59 PM
qwertz9586's Avatar
For frame of reference, the entire system takes 12 to 14 quarts.
qwertz9586 is offline
post #5 of 6 (permalink) Old 09-09-2015, 09:25 AM
Most recent ATF change on 2002 AX4N drain and fill needed 9qts. 5.5 qts only foamed the ATF with slow jerky gear engagement.
Previous ATF changes needed 6-7 qt.
Your mileage may vary.
midday is offline
post #6 of 6 (permalink) Old 09-09-2015, 09:31 AM
Bullwinkle's Avatar
Year: 2011
Engine: 3.5L Ti-VCT V6
Recommended to use a flush machine. Otherwise you are only changing about half the fluid. Unless you want to do it several times. Partial fluid changes leave contaminates in the system and will dirty new fluid a lot quicker. Trans services will need to become more frequent to keep clean fluid in it. Worth the money to have a reputable shop do it
A man who dares to waste one hour of time has not discovered the value of life. - Charles Darwin
Bullwinkle is offline
