Istallation Of Throttle Position Sensor - Taurus Car Club of America : Ford Taurus Forum
post #1 of 14 (permalink) Old 05-20-2009, 06:01 PM Thread Starter
Unhappy
hi i wasn't sure how to put the throttle position sensor on the throttle body if you just put it right on or is there a special way to install it
the car is a 1998 ford taurus se DOHC
need help
thacks
holger_2 is offline
post #2 of 14 (permalink) Old 05-20-2009, 06:14 PM
spridget's Avatar
There should be a slight pre-load on the sensor when it's installed. Determine which way the throttle opens (clockwise or counter-clockwise). There is a tab on the end of the throttle shaft that fits into the sensor. When you place the sensor on the throttle body in the correct position, the screw holes won't line up at first. You'll need to rotate the sensor opposite direction of the TB opening, but no more than 5 degrees. That is the pre-load.
RIP TCCA
'96 ES SHO -
spridget is offline
post #3 of 14 (permalink) Old 05-20-2009, 06:23 PM Thread Starter
QUOTE (spridget @ May 20 2009, 06:14 PM)
There should be a slight pre-load on the sensor when it's installed. Determine which way the throttle opens (clockwise or counter-clockwise). There is a tab on the end of the throttle shaft that fits into the sensor. When you place the sensor on the throttle body in the correct position, the screw holes won't line up at first. You'll need to rotate the sensor opposite direction of the TB opening, but no more than 5 degrees. That is the pre-load.[/b]
thanks would any other year would fit or it had to be the same exact year and model
like not a DOHC
holger_2 is offline
post #4 of 14 (permalink) Old 05-22-2009, 02:18 AM
spridget's Avatar
Best to use exact year and model, but other years may fit. There are two types of TPS, clockwise and counter-clockwise. They are not interchangeable. If you rotate the TPS the wrong way it will break. They are rather delicate parts. So if you rob a TPS from a salvage car, make sure it rotates the same direction as the car you are repairing.
RIP TCCA
'96 ES SHO -
spridget is offline
post #5 of 14 (permalink) Old 05-22-2009, 12:33 PM Thread Starter
QUOTE (spridget @ May 22 2009, 02:18 AM)
Best to use exact year and model, but other years may fit. There are two types of TPS, clockwise and counter-clockwise. They are not interchangeable. If you rotate the TPS the wrong way it will break. They are rather delicate parts. So if you rob a TPS from a salvage car, make sure it rotates the same direction as the car you are repairing.[/b]
thanks for the help didn't know that and wanted to make sure before i did anything
holger_2 is offline
post #6 of 14 (permalink) Old 07-07-2009, 09:53 AM
How did you make out with your Throttle Position Sensor ???? I am actually doing one this weekend and have never done one. I have a 1998 Mercury Sable with the DOHC motor. Any suggestions you could give me would be greatly appreciated.. Thanks Eddy
cosmo02905 is offline
post #7 of 14 (permalink) Old 07-07-2009, 07:25 PM Thread Starter
QUOTE (cosmo02905 @ Jul 7 2009, 09:53 AM)
How did you make out with your Throttle Position Sensor ???? I am actually doing one this weekend and have never done one. I have a 1998 Mercury Sable with the DOHC motor. Any suggestions you could give me would be greatly appreciated.. Thanks Eddy[/b]
well did mine already and just be carefull beacuse i broke one and was not kool probably while your add it u might want to clean ur throttle if u have not done that you'll be suprise what u find inside the throttle body
thats just me thats all u can do and like the other replays i got just check its good advise
holger_2 is offline
post #8 of 14 (permalink) Old 07-12-2009, 12:48 AM
QUOTE (Holger @ Jul 7 2009, 07:25 PM)
I replaced my tps and tha car is still having the same issues.... It idles high when it is first started then it idles normal for a while... Then all of a sudden it starts idling at about 30900.. Someone please help !!!!
post #9 of 14 (permalink) Old 07-12-2009, 08:47 AM
What is the voltage on the middle wire when the key is on and the engine off?
post #10 of 14 (permalink) Old 07-12-2009, 10:50 AM
TPS voltage should be set at about 0.98v with the throttle closed.
Make sure you check for vaccum leaks before replacing a bunch of parts that may not be bad.
It takes 8,460 bolts to assemble an automobile and one nut to scatter it all over the road
liftedcj7on44s is offline
