Airbag Light Code 3-6 - Taurus Car Club of America : Ford Taurus Forum
post #1 of 7 (permalink) Old 02-12-2009, 12:49 PM Thread Starter
Oh, my mighty TCCA members... I have searched and searched long and hard for the answer to this question with no avail, so please do not group me into the "newbie" class of asking a question that has been posted 13 times already! lol. But I AM a long time user, first time poster (and glad to be a member with all the help you guys have already given me).
Details: 2000 Merc Sable (Duratec, in case it matters): Flashing airbag code 3-6. I have seen postings here for other year cars with the list of codes so I am hopeful that there is an answer out there.
Thanks again,
erm
elyrmoore is offline
post #2 of 7 (permalink) Old 02-12-2009, 01:14 PM
Here's the air bag codes for the 2000 Taurus.
Diagnostic Test Codes (DTCs)
While the lamp fault codes (LFCs) are an indication of a general concern in the passive restraints system, the diagnostic test codes (DTCs) are more specific. The DTCs can be retrieved from the restraints control module (RCM) with a scan tool via the data link connector (DLC).
Because an LFC may be the first indication of a system concern, the following table lists the DTCs in the numerical order of the associated LFC.
Restraints Control Module (RCM) Diagnostic Trouble Code (DTC) Priority Table DTC a LFC b Fault Priority Description Action To Take
— Steady 1 RCM Disconnected, Inoperative, or Lost/Low Ignition Feed Go To Pinpoint Test A .
B1891 13 34 Air Bag Tone Warning Indicator Circuit Short to Battery Go To Pinpoint Test B .
B1892 13 34 Air Bag Tone Warning Indicator Circuit Shorted to Ground or Open Go To Pinpoint Test C .
B1901 14 14 Front Crash Sensor Circuit Short to Ground Go To Pinpoint Test D .
B2225 14 14 Front Crash Sensor Mounting Fault Go To Pinpoint Test E .
B2226 14 14 Front Crash Sensor Internal Fault INSTALL a new front crash sensor.
B2227 14 14 Front Crash Sensor Communications Fault Go To Pinpoint Test E .
B1887 15 6 Driver Air Bag Squib 1 Circuit Short to Ground Go To Pinpoint Test F .
B1916 15 6 Driver Air Bag Squib 1 Circuit Short to Battery Go To Pinpoint Test F .
B1888 16 7 Passenger Air Bag Squib 1 Circuit Short to Ground Go To Pinpoint Test G .
B1925 16 7 Passenger Air Bag Squib 1 Circuit Short to Battery Go To Pinpoint Test G .
B1878 17 30 Driver Pretensioner Circuit Short to Battery Go To Pinpoint Test H .
B1879 17 30 Driver Pretensioner Circuit Short to Ground Go To Pinpoint Test H .
B1882 18 31 Passenger Pretensioner Circuit Short to Battery Go To Pinpoint Test I .
B1883 18 31 Passenger Pretensioner Circuit Short to Ground Go To Pinpoint Test I .
B1231 19 3 Crash Data Memory Full INSTALL a new RCM.
B1921 21 4 RCM Bracket Ground Resistance High Go To Pinpoint Test J .
B2432 22 32 Driver Buckle Switch Circuit Fault Go To Pinpoint Test K .
B2436 23 33 Passenger Buckle Switch Circuit Fault Go To Pinpoint Test L .
B1342 24 2 RCM is Faulted INSTALL a new RCM.
C1946 26 17 Seat Position Switch Circuit Fault Go To Pinpoint Test M .
B2228 28 12 Driver Air Bag Squib 2 Circuit Short to Ground Go To Pinpoint Test N .
B2230 28 12 Driver Air Bag Squib 2 Circuit Short to Battery Go To Pinpoint Test N .
B2232 28 12 Driver Air Bag Squib 2 Circuit Open Go To Pinpoint Test O .
B2234 28 12 Driver Air Bag Squib 2 Circuit Resistance Low Go To Pinpoint Test O .
C1414 29 5 Incorrect Vehicle Identification Code Go To Pinpoint Test P .
B2229 31 13 Passenger Air Bag Squib 2 Circuit Short to Ground Go To Pinpoint Test Q .
B2231 31 13 Passenger Air Bag Squib 2 Circuit Short to Battery Go To Pinpoint Test Q .
B2233 31 13 Passenger Air Bag Squib 2 Circuit Open Go To Pinpoint Test R .
B2235 31 13 Passenger Air Bag Squib 2 Circuit Resistance Low Go To Pinpoint Test R .
B1932 32 8 Driver Air Bag Squib 1 Circuit Open Go To Pinpoint Test S .
B1933 33 9 Passenger Air Bag Squib 1 Circuit Open Go To Pinpoint Test T .
B1934 34 10 Driver Air Bag Squib 1 Circuit Resistance Low Go To Pinpoint Test U .
B1935 35 11 Passenger Air Bag Squib 1 Circuit Resistance Low Go To Pinpoint Test V .
B1992 36 24 Driver Side Air Bag Circuit Short to Battery Go To Pinpoint Test W .
B1993 36 24 Driver Side Air Bag Circuit Short to Ground Go To Pinpoint Test W .
B1994 36 24 Driver Side Air Bag Circuit Open Go To Pinpoint Test X .
B1995 36 24 Driver Side Air Bag Circuit Resistance Low Go To Pinpoint Test X .
B1996 37 25 Passenger Side Air Bag Circuit Short to Battery Go To Pinpoint Test Y .
B1997 37 25 Passenger Side Air Bag Circuit Short to Ground Go To Pinpoint Test Y .
B1998 37 25 Passenger Side Air Bag Circuit Open Go To Pinpoint Test Z .
B1999 37 25 Passenger Side Air Bag Circuit Resistance Low Go To Pinpoint Test Z .
B2441 42 20 Driver Side Crash Sensor Mounting Fault Go To Pinpoint Test AA .
B2440 43 21 Passenger Side Crash Sensor Mounting Fault Go To Pinpoint Test AB .
U2017 44 22 Driver Side Crash Sensor Communications Fault Go To Pinpoint Test AC .
U2018 45 23 Passenger Side Crash Sensor Communications Fault Go To Pinpoint Test AD .
B1877 46 26 Driver Pretensioner Circuit Open Go To Pinpoint Test AE .
B1885 46 26 Driver Pretensioner Circuit Resistance Low Go To Pinpoint Test AE .
B1881 47 27 Passenger Pretensioner Circuit Open Go To Pinpoint Test AF .
B1886 47 27 Passenger Pretensioner Circuit Resistance Low Go To Pinpoint Test AF .
B2444 48 18 Driver Side Crash Sensor is Faulted INSTALL a new driver side crash sensor.
B2445 49 19 Passenger Side Crash Sensor is Faulted INSTALL a new passenger side crash sensor.
B1869 Tone c 32 Air Bag Indicator Circuit Open Go To Pinpoint Test AG .
B1870 Tone c 33 Air Bag Indicator Short to Battery Go To Pinpoint Test AG .
post #3 of 7 (permalink) Old 02-12-2009, 01:40 PM Thread Starter
The DTCs can be retrieved from the restraints control module (RCM) with a scan tool via the data link connector (DLC).[/b]
First, thanks for such a quick and in depth responce. One question though, is this a code that Autozone can pick out for me with their tool? And if so is it something that, once I know the more in depth code, would I be able to fix myself? I understand that working with the airbag system can be potentially dangerous and being at only a semi-novice experience level myself, should I just skip it and shell out the dough for a mechanic (or possibly dealer ) if need be? On that note, is it even something that I "need" to worry about? Will this effect my inspection? Obviously, problems with my airbag is 'potentially' a problem (like if I got in an accident), but how soon do I need to do something about it?
--erm
post #4 of 7 (permalink) Old 11-06-2012, 10:05 PM
how to perform pinpoint test y and z
i am new to this forum but after reading your post i tred to click on "go to pinpoint test y and go to pinpoint test z, each time my microsoft word program could not read it. can you tell me how to perform the pinpoint test above in lamen terms. i dont have a problem getting in and doing the work i just dont know how to perform this testing and there is no instruction on the web i could find.
the reason i need this test performed is my airbag light is flashing 3 then 7 repetatively i tried to reset by disconnecting battery but that didnt work. my wife says the light started flashing after going over a school speedbump at 5 mph???
thanks a bunch
mpayton0818 is offline
post #5 of 7 (permalink) Old 11-07-2012, 10:03 AM
thanks a bunch
The code might be the driver side seat belt sensor if she was only occupant. Not sure on the flashes but I had a 3 4 and it was a sensor on passenger seat.
Do not know it was the correct code but when I changed the passenger seat belt out it was golden.
If I find the code I will report back~~
downhill is offline
post #6 of 7 (permalink) Old 11-07-2012, 10:51 AM
downhill is offline
post #7 of 7 (permalink) Old 11-07-2012, 11:54 AM
I believe the 3 7 is refering to issues with the passenger side airbag. You should have a shop (Dealer) read the codes and investigate. Airbags are dangerous things.
B1996 37 25 Passenger Side Air Bag Circuit Short to Battery.
B1997 37 25 Passenger Side Air Bag Circuit Short to Ground .
B1998 37 25 Passenger Side Air Bag Circuit Open.
B1999 37 25 Passenger Side Air Bag Circuit Resistance Low.
2000 Duratec SE White Wagon
crackhead is offline
