Dead Battery Again, Clicking Noise - Taurus Car Club of America : Ford Taurus Forum
Old 10-21-2008, 12:14 PM   #1 (permalink)
Member Number: 17018
twiztedstudiez has a little shameless behaviour in the past
Send a message via AIM to twiztedstudiez Send a message via MSN to twiztedstudiez Send a message via Yahoo to twiztedstudiez
I bought a new battery a couple days ago and have drove with it a couple times since then and everything seemed fine. Today I went out to my car to turn the tires so I could start working on the CAI and the battery is dead AGAIN. Completely dead. When I try to turn the ignition I hear a constant clicking noise down by the brake pedal.
Click-click-click-click.... even with the keys out of the ignition.
I'm pretty mad now that I bought this battery and it worked fine for a few days and now it's dead again. Any ideas on what it might be? And what is clicking.
1999 Ford Taurus SE Vulcan / Tan in Black out
Currently: Fixing electrical problem, trunk
Delta 417- Technology Forum
twiztedstudiez is offline   Reply With Quote
Old 10-21-2008, 01:30 PM   #2 (permalink)
Member Number: 5485
gohim has a little shameless behaviour in the past
Your car probably has a bad/or some bad connections between the battery, the alternator, the starter, and chassis ground.
The battery will not charge without good solid electrical connections. The alternator connects with the positive battery terminal down on the starter, and and with ground on the left inner fender.
On my Taurus Wagon, the ground connection on the left inner fender was covered with cloth electrical tape at the Ford Factory (probably to protect it from corrosion. The connection was slightly corroded, and loose when I removed the tape to inspect it when I had a similar problem to yours.
gohim is offline   Reply With Quote
Old 10-21-2008, 05:37 PM   #3 (permalink)
Member Number: 11378
While gohim is most probably right, once many years ago, I had a brand new battery last all of 2 weeks due to a shorted cell. Might want to get the new batt checked out just for the heck of it.
02 Pontiac Grand Prix GT
Old 10-21-2008, 08:06 PM   #4 (permalink)
I'm thinking it's the connections on the battery terminals. I played around with them a bit and pushed them down hard and the car started right up after about 2-3 trys of moving the cables around on the terminals.
The ends of the cable that connect to the battery posts are definitely rusted/corroded quite a bit, mainly the negative side. Is there better quality cables I can buy to replace them and does anyone have a how-to on how to do it. Also, I have a sound system (been unhooked for a while since I'm redoing my trunk liner) so I'd also like a battery cable that's easy to hook my amp to.
The ground cable from the battery is in perfect condition and is still factory tight.
Here's a picture:
