Trans Cooler. - Taurus Car Club of America : Ford Taurus Forum
post #1 of 11 (permalink) Old 08-19-2008, 01:09 AM Thread Starter
Will an aftermarket large trans cooler lengthen the life of my transmission? The stock one seems kinda small, and it incorporates the PS cooler too, I'm not sure I like that. thanks. tkuerzinge
tkuerzinge is offline
post #2 of 11 (permalink) Old 08-19-2008, 03:46 AM
I would say a larger cooler will cool the trans oil faster (the oil can only gets into the cooler only if its hot enough)... But I wouldn't guess how much it counts in real life.
An external, standalone cooler is recommended... you can't do wrong wiith that... But I wouldn't say a larger would lenghten the trans life that much that it counts.
Zolee87GT is offline
post #3 of 11 (permalink) Old 08-19-2008, 05:39 AM Thread Starter
thanks for the input. much appreciated. tkuerzinge
post #4 of 11 (permalink) Old 08-19-2008, 12:01 PM
Send a message via AIM to jmoschetti45 Send a message via MSN to jmoschetti45 Send a message via Yahoo to jmoschetti45 Send a message via Skype™ to jmoschetti45
A trans cooler can extend the life of the trans if your primarily driving around the city a lot where it gets less air into the front and shifts more.
Joe Moschetti
New Car: 2005 Subaru Forester 2.5 X MTX
SHO Wagon Status: Running, but rust killed the body, and it has no brakes period... Moth balling has begun...
RIP: 1998 White SE Wagon (1/31/2008 @ 23:47)
jmoschetti45 is offline
post #5 of 11 (permalink) Old 08-19-2008, 12:52 PM
silvapain's Avatar
An external, standalone cooler is recommended... you can't do wrong wiith that... But I wouldn't say a larger would lenghten the trans life that much that it counts. [/b]
There is no internal thermostat on our transmissions - the tranny fluid is always flowing through the coolers. Therefore, if you live in a more northern area I suggest a remote tranny thermostat - I have a PermaCool unit from Summitracing.com. You CAN overcool the transmission in the winter.
Yes, an auxillary cooler does extend transmission life by preventing thermal breakdown of the transmission fluid, which is very common on Taurus transmissions. I'm running a gen 2 SHO ATX cooler and I have bypassed the OE in-radiator cooler but have retained the use of the OE aux cooler.
Welcome to the club Zolee87GT, but maybe you should do some more reading on this forum before you start offering help?
- Daniel
Current:
Past:
1997 V8 SHO Silver Frost -
1997 V8 SHO Ebony Satin -
1997 Vulcan GL -
1990 Vulcan Sable -
silvapain is offline
post #6 of 11 (permalink) Old 08-19-2008, 04:59 PM
Welcome to the club Zolee87GT, but maybe you should do some more reading on this forum before you start offering help?[/b]
Sorry, my bad. I did not mention I always used self-regulating trans coolers. When the oil is in normal heat range, it bypasses the cooler through a bypass valve. When the oil heats up, gets thin enough, than it flows through the cooler.
post #7 of 11 (permalink) Old 08-19-2008, 05:07 PM
silvapain's Avatar
FWIW, this is what I use:
http://store.summitracing.com/partdetail.a...mp;autoview=sku
- Daniel
Current:
Past:
1997 Vulcan GL -
1990 Vulcan Sable -
post #8 of 11 (permalink) Old 09-17-2008, 01:44 AM
Send a message via Yahoo to masaki
Hi, I have a ford taurus LX 1988 with V6 3.0L engine, I want to add a trans cooler and bypass the radiator in cooler, I want to know If I really need a thermostat to bypass the oil, I'm from Peru, the local temperature is: 12º C (winter) to 30º C (summer)
Personal car
Ford Taurus LX SW 1988 V6 3.0L
weekend project car...
GMC Chevrolet Blazer 1972 4WD
masaki is offline
post #9 of 11 (permalink) Old 09-17-2008, 03:19 AM
No you don't really need the t-stat. A lot depends on the driving. If it is stop and go or city driving or mountain driving it will still get quite warm. If it is all open road then you may have problems getting the temp over 50C. Still no big deal.
Silvapain and I are both flatlanders.
post #10 of 11 (permalink) Old 09-17-2008, 08:32 AM
silvapain's Avatar
Silvapain and I are both flatlanders.[/b]
...that live out in the country, no less. Lots of high-speed country roads that makes it hard for the tranny to get up to temps in the winter.
- Daniel
Current:
Past:
1997 Vulcan GL -
1990 Vulcan Sable -
