Member Number: 16321
Ford Taurus 1999 SE Wagon
- What is the fair price to replace 2 front ball joints? How long usually does it take? - What store usually have the best price for replacing tires? Thanks!
#2 (permalink) | |
Member Number: 3969
Drives: 2003 Mercury Grand Marquis LS 4.6
It's always best to shop around for tires; some offer a free alignment with the purchase of 4 tires. Some may have specials/rebates. I always shop around and check the chain stores and local tire shops.
2003 Mercury Grand Marquis 2002 Taurus SE "Evelyn" 221K+ miles 3.0 Vulcan AX4S - RIP 1995 Taurus GL "Bonnie" 72000 miles 3.0 Vulcan AX4N - RIP If you need help with a Taurus problem, feel free to PM me or www.taurusowners.com |
How much does it usually cost to replace the 2 front outer tie-rods (parts+labor)?
Thanks!
Member Number: 5485
Replace the tierod ends yourself in a few minutes.
All you have to do is buy the replacements, then unscrew the old ones, one at a time, counting the number of turns it takes to remove. Then just screw the replacements on the same number of turns. |
#5 (permalink) | |
Member Number: 16684
Gads...and some shops charge $500 for that. |
Member Number: 12596
Drives: 1997 Mercury Sable LS
Rep Power: 7 ![]() |
Ball Joints are a PITA it seems on any car. If you're a $hit fister you can save major bucks if you're willing to most of the work yourself. It takes a special tool to "pop" the old ball joint out and "pop" the new ball joint in. In a nutshell these new joints are pressed-in. I had to take my knuckles in to the local NAPA store and have this process done.
Does anyone know if these ball joint may have grease fittings? The ABS ring is not far away form the ball joint. I don't where one would put a grease fitting? The factory ball joints are sealed. I have been removing the ball joint boot to pack the boot with grease and slip the boot back on. I don't know if this the best way to grease the ball joint but its better than nothing.
>> In God we trust; all others bring data. >> Me Like MACH Audio... >> Factory Certified Glock Armor >> ASQ Certified Software Quality Engineer >> 220K+ Duratec Mile Club >> Motorcraft. What's in your Ford ? |
Member Number: 125
When replacing tie rod ends be sure they are the same length. If the new ones are a different length than the number of turns thing doesn't work.
Paul Nimz '10 Red Genesis Coupe '08 Hyundai Accent |
Member Number: 5766
you gonna need a ball joint/tierod seperator tool
or a picklefork, but those suck.
-Andrew ![]()
#9 (permalink) |
Member Number: 125
I've found the small pitman arm puller works great on the tire rod end, just leave the castle nut on. And the large one will pop the ball joint loose from the control arm very easily also.
AutoZone rents them or you can buy them for the cheap.
