Transaxle Light Problem - Taurus Car Club of America : Ford Taurus Forum
post #1 of 13 (permalink) Old 07-20-2008, 02:05 PM Thread Starter
Hi guys,
I bought 2000 Taurus SE 6 months ago and today I noticed that TRANSAXLE light (light with exclamation mark) never comes ON when key is in ignition. All lights are working but that's only light that never comes ON. (see image)
Missing Transaxle light should be next to the ABS light. Is there anyone that have 2000 Taurus SE to give me info should I have this light lit or not? That would save me a lot of time because I don't want to take a instrument panel apart if it's not necessary.
I'm afraid that previous owner maybe disabled that light before sale in order to hide transaxle problem.
There are also some other light that never comes on like LOW COOLANT and CHECK FUEL CAP but TRANSAXLE light is what concerns me at this moment.
Thank you,
G
Klikerko is offline
post #2 of 13 (permalink) Old 07-20-2008, 02:38 PM
Guest
Send a message via AIM to 5766
you car probably didnt have that feature
ford used universal instrument panels for all their taurus's and didnt put in lights for things the car doesnt have.
my 99 doenst have a transaxle "!" light.
5766 is offline
post #3 of 13 (permalink) Old 07-20-2008, 08:43 PM Thread Starter
Thanks Andrew, I also have to check is there LOW COOLANT light on my instrument panel.
Klikerko is offline
post #4 of 13 (permalink) Old 07-20-2008, 10:41 PM
If your car has the vulcan engine, then the low coolant light isn't supposed to work. Only the duratec cars had a coolant level sensor.
- Barenaked Ladies
Nidan is offline
post #5 of 13 (permalink) Old 07-20-2008, 10:47 PM
Trader Score: 7 reviews
The ( ! ) for the transaxle worked in my 2000 cluster works fine. The light might have burned out. I can give you a link on how to take the dashboard apart and fix this if you're interested (it also gives you a chance to replace any burnt out lights in your instrument cluster backlighting).
--Nick
bull geek is offline
post #6 of 13 (permalink) Old 07-21-2008, 07:00 PM Thread Starter
Yes please, link will be fantastic.
I have Haynes service manual but I would like to read more information before I start. I'm not happy to hear that transaxle light should work... Now I'm afraid that maybe someone disconnected the light before sale to mask transmission problem. I mean, what are the odds that transaxle bulb is burnt....
Klikerko is offline
post #7 of 13 (permalink) Old 07-21-2008, 07:05 PM
<div class='quotemain'>
The ( ! ) for the transaxle worked in my 2000 cluster works fine. The light might have burned out. I can give you a link on how to take the dashboard apart and fix this if you&#39;re interested (it also gives you a chance to replace any burnt out lights in your instrument cluster backlighting).
I have Haynes service manual but I would like to read more information before I start. I&#39;m not happy to hear that transaxle light should work... Now I&#39;m afraid that maybe someone disconnected the light before sale to mask transmission problem. I mean, what are the odds that transaxle bulb is burnt....
The "Check Transaxle" warning light is normally off and does not test with key on/ignition off like other warning lights. It only illuminates (flashes) if there is a problem detected in the transaxle.
2003 Mercury Grand Marquis
2002 Taurus SE "Evelyn" 221K+ miles 3.0 Vulcan AX4S - RIP
1995 Taurus GL "Bonnie" 72000 miles 3.0 Vulcan AX4N - RIP
If you need help with a Taurus problem, feel free to PM me or
rdh2 is offline
post #8 of 13 (permalink) Old 07-21-2008, 10:25 PM
I was double checking the owners manual for a 2000...and it doesn&#39;t mention that it should ever illuminate, but yet the 01-03 owners manual onwards does. Starting the car up *should* run a test on the bulbs anyways as it says:
Check transaxle
Momentarily illuminates when the
ignition is turned to the ON position.[/b]
Here&#39;s how to take apart your dashboard...have fun
http://www.taurusclub.com/forum/inde...howtopic=57274
--Nick
post #9 of 13 (permalink) Old 07-21-2008, 10:28 PM
trus03's Avatar
Send a message via AIM to trus03
I just checked my 03 Taurus tonight. When I turn the key to the "ON" position, the (!) transaxle light briefly illuminates.
2003 Ford Taurus SEL Centennial Edition
"Ashes to ashes, dust to dust;
If it wasn't for the Taurus, our tools would rust"
trus03 is offline
post #10 of 13 (permalink) Old 07-28-2008, 12:34 AM Thread Starter
Well guys, I removed the dashboard today and checked instrument panel. This is what I had found.
On the back side of instrument panel is a number of easy to remove bulbs and all bulb holes are marked. I noticed that there are some holes marked but missing and that was of course done in the factory since I don&#39;t have those features on my car ("rear light out" for example).
I noticed that I have a hole and a bulb for "low coolant" but as Nidan said my Vulcan engine shouldn&#39;t have that feature. I will check tomorrow coolant tank again to see is there a sensor.
Back to (!) transaxle light... There is a hole and there is a bulb for that feature. I put a new bulb there and nothing happened. I put a bulb from (!) transaxle to "brake" and bulb illuminated. So, bulb is OK. Then I used multimeter and checked voltage on "transaxle" light contacts and there was steady 12V when ignition is ON. But why all bulbs that I tried (and I tried at least 5 of them) didn&#39;t want to illuminate? I was confused. I couldn&#39;t solve this...
Then I found something really interesting and I will be very thankful if someone experienced could explain this to me. There is a "brake" bulb. That bulb illuminates just for a few seconds when ignition is ON which is normal. I removed that bulb (in pure desperation because I couldn&#39;t solve transaxle light problem) and placed multimeter to check for a voltage when ignition is ON. It was steady 12V and after a few seconds it was still 12V but how that bulb turned off when there is a power?
At the end, I checked all the wires, everything was OK. All bulbs are OK but transaxle light doesn&#39;t illuminate. RDH2 said that light shouldn&#39;t illuminate but then Bull Geek said it illuminates on his 2000. I don&#39;t know how to solve this... I&#39;m ready to give up.
Klikerko is offline
