Dash Lights Out - Taurus Car Club of America : Ford Taurus Forum
post #1 of 16 (permalink) Old 06-27-2008, 02:32 PM Thread Starter
When I turn on the parking lights OR headlamps the dash lights will not come on, except for the turn indicators (inside only) will light up solid. Indicators will blink when turn signal is activated but go back to solid when turn is canceled…all this only when the headlamps are on. Outside everything seems to be in order.
I have read other posts pointing to the multifunction switch, but those issues are related to washer functions. I'm not sure if my problem deals with the MFS or not??
I've checked ALL the fuses in the panel box...as well as all them under the hood. Problem remains!
Please chime in if you know of this problem OR know what the fix is!!
Scott Hensley is offline
post #2 of 16 (permalink) Old 06-27-2008, 03:27 PM
qwertz9586's Avatar
Do the dash lights work when parking lights are on only?
qwertz9586 is offline
post #3 of 16 (permalink) Old 06-27-2008, 03:40 PM Thread Starter
Arrow
Nope!
post #4 of 16 (permalink) Old 06-27-2008, 05:00 PM
Turn the little dimmer wheel next to the light switch.......
If that doesn't work you have a blown fuse.
1969 Cougar XR 7 351W
sfhess is offline
post #5 of 16 (permalink) Old 06-27-2008, 09:44 PM
Send a message via AIM to barticus
its a blown fuse if ur turn signals are on constantly when u have headlights on or if they both blink when u have turn signal on. happened to my jobs ford econoline
2000 Dodge Intrepid 2.7L SE- blown engine, bad tranny
2003 Ford Taurus Centennial- Current
barticus is offline
post #6 of 16 (permalink) Old 06-30-2008, 08:29 AM Thread Starter
Arrow
Do you recall if it was odd type fuse?? I've checked all the obvious ones and they are all good.
When I turn on the headlamps the dash lights will not come on, except for the turn indicators (inside only) will light up solid. Indicators will blink when turn signal is activated but go back to solid when turn is canceled…all this only when the headlamps are on. Outside everything seems to be in order.
Dealer says multifunction switch. Anyone else agree or think this switch can be part of the problem?
post #7 of 16 (permalink) Old 06-30-2008, 09:52 AM
I had the same problem, except it was intermittent. My tail lights would got out too sometimes. It turned out it was a bad ground on the gauge cluster and the whole thing had to be replaced $$$
plato is offline
post #8 of 16 (permalink) Old 06-30-2008, 03:01 PM
I suspect i have the same problem, as i already replaced a blown fuse for my dash lights, and the same fuse blew out. What do yall think?
RyKnow is offline
post #9 of 16 (permalink) Old 06-30-2008, 03:09 PM
Well if you are blowing fuses you have a short somewhere. Get out the ohm meter and start testing the wires to ground.
post #10 of 16 (permalink) Old 01-16-2009, 08:15 AM
SCOTTY, Ii have the same problem. What did you do to finally fix the lamp problem?
tpaul is offline
