Sunroof Problem Solved - Taurus Car Club of America : Ford Taurus Forum
Old 06-21-2008, 11:27 AM   #1 (permalink)
Member Number: 5848
jndejure has a little shameless behaviour in the past
After more than a week passing and not a single reply to my request for help on a noisy sunroof I decided to go it alone and remove the complete assembly from the car (05 Sable). Cleaned the tracks and drive springs with brake cleaner and air pressure, re-lubed, reassembled and installed back in the car. Same problem, loud clicking and popping noises, so out it came again. This time I took a good look at the drive area and what makes it work and decided that it needed some shims placed strategically behind the drive spring flashing on either side of the drive gear. Also, added more lube on the tracks and removed the spring clips from inside the front white nylon runners to reduce friction even more. Sunroof fixed!
Works slick and smooth as new now. If anyone wants to know more about what was needed and how to make the shims and their complete dimensions just email me and I can post a complete write up on their construction and installation. Did this after days of searching for parts on the net and finding that no one wanted to do anything but sell me a new assembly for between $700.00 and $1,400.00 or a used one between two to three hundred bucks. No thanks to either of these solutions. New would still have to be installed and used would more than likely be close to having the same or similar problems. Don't be afraid of your sunroof, it won't bite.
jndejure is offline   Reply With Quote
Old 06-21-2008, 03:59 PM   #2 (permalink)
darthenstein's Avatar
Member Number: 2818
darthenstein has a little shameless behaviour in the past
Sounds good...sometimes we don't always know what is going on and don't want to say anything if we are not sure. It's great that you were able to fix it! Thanks for the info!
"It isn't what you drive that matters, it's how you drive it"
- Jeremy Clarkson, Top Gear
Ford: Taurus ('91, '01) Focus ('09)
Mercury: Sable ('95)
Dodge: Neon ('95)
Trek: 1000SL ('07)
darthenstein is offline   Reply With Quote
Old 06-21-2008, 04:35 PM   #3 (permalink)
Member Number: 5784
giant has a little shameless behaviour in the past
glad you were successful. sometimes you just gotta rip into something like that and see whats up.
giant is offline   Reply With Quote
Old 12-23-2012, 07:28 PM   #4 (permalink)
Member Number: 51881
Drives: 2004 Taurus SES
Jeffrey is an unknown quantity at this point
Would love to know exactly what you did to fix it as it sounds like I am having the same issue. However, seeing as I do not have the greatest automotive skills I am really just looking to get it closed and water tight.
Jeffrey is offline   Reply With Quote
Old 12-23-2012, 08:07 PM   #5 (permalink)
Lgbpop's Avatar
Member Number: 7489
Congrats on solving it. I imagine sunroofs don't get much attention, being optional and all. You'd be doing everyone here a huge service by putting up some photos and a step-by-step tutorial on how you removed it from the car, what you did to repair and any tips on re-installing it.
Lgbpop is online now   Reply With Quote
Old 12-23-2012, 08:33 PM   #6 (permalink)
sheila is just really nice
^ Necropost, lol. 4-5 yrs. old.
Old 12-23-2012, 11:08 PM   #7 (permalink)
The Page 93 Mastermind
TaurusDailyDriver's Avatar
Member Number: 42443
TaurusDailyDriver has a spectacular aura about
I put a factory one in my car... so I know these things well! What exactly is going on with yours Jeffrey? I will do my best to help you pinpoint it.
The most common issues of these is the black plastic cracking. Inspect that piece first. When this breaks loose from the water drain or cracks, it causes all sorts of issues.
Haha thread from the dead has been revived!
I will gladly pull mine apart and do a tutorial.
Paul T.
|2006 Taurus SE | Silver Frost |The 'Official' Bull of Central New York! | October 2012 COTM
|2005 Taurus SEL| Vibrant White | The Stock Bull
|1999 Taurus SE |
Toreador Red | Retired with 112k
TaurusDailyDriver is offline   Reply With Quote
Old 12-24-2012, 08:06 AM   #8 (permalink)
Member Number: 1771
All that stupid black plastic piece does is pull the sun shade forward an inch when you close the moonroof all the way so you can put your hand on the grab handle. Otherwise, the sun shade just stays tucked behind the headliner (which you can manually just grab up and close).
Opening the sunroof there are two pieces of metal that are hit on the sunshade that are pushed back to bring the sunshade back.
Sold....
Scrapped...
Old 12-24-2012, 10:07 AM   #9 (permalink)
Member Number: 47403
Drives: 2004 SES
Bob R is an unknown quantity at this point
I'll never get another car with a sun roof. I believe it's part of the reason this Taurus is the noisiest Taurus I have ever owned. Plus....I don't even use it. Came with the car when I bought it used so I had no choice.
Bob R is online now   Reply With Quote
Old 12-24-2012, 01:28 PM   #10 (permalink)
What is so noisy about it?
Paul T.
|1999 Taurus SE |
