Sunroof Problem Solved - Page 2 - Taurus Car Club of America : Ford Taurus Forum
Old 12-24-2012, 01:44 PM   #11 (permalink)
QuinnSHO's Avatar
Member Number: 37321
Drives: I own a 1996 Black Taurus SHO
QuinnSHO is on a distinguished road
^I still need to ask you about my roof issue... (and how in gods name do they even come apart)
QuinnSHO is offline   Reply With Quote
Old 12-24-2012, 01:57 PM   #12 (permalink)
it'sthatcar's Avatar
Member Number: 49561
Chapter: Northern
it'sthatcar is on a distinguished road
My sunroof is very noisy too. I found out at very high speeds the wind will move the glass up and down in the frame. I'm going to put some weather stripping in there to see if that reduces the wind noise.
Sent from my iPhone using AutoGuide.com Free App
it'sthatcar is offline   Reply With Quote
Old 12-24-2012, 02:27 PM   #13 (permalink)
The Page 93 Mastermind
TaurusDailyDriver's Avatar
Member Number: 42443
TaurusDailyDriver has a spectacular aura about
@Quinn
There are a number of screws holding in the track to the tray. The sunroof motor also needs to be removed prior to the removal of the track... It is held by a couple screws as well. Once you do that, it is fairly easy to wiggle out.
@thatcar
Yes, the air pressure pulls on the glass. This happens to all cars... it is just a matter of how well they plan for it. The sunroof design is from 1995.. Mine is loose at the moment so I know exactly what you mean about the vacuum created pulling the glass upward of speeds over 50. Weather stripping or something similar is only a good idea if you do NOT use your sunroof. The rubber around the glass will catch on anything resistive if you are trying to close it. It will catch and not close either from vent or being completely open. You may benefit from making sure everything is tight. It should not have much play. You can always attempt to readjust your glass by loosening and re-tightening the screws holding the glass in. To get to these, carefully pop the plastic piece shown above and slide it back into the roof exposing the screws. Just do not open it when you do that!!!
Paul T.
|2006 Taurus SE | Silver Frost |The 'Official' Bull of Central New York! | October 2012 COTM
|2005 Taurus SEL| Vibrant White | The Stock Bull
|1999 Taurus SE |
Toreador Red | Retired with 112k
TaurusDailyDriver is offline   Reply With Quote
Old 12-24-2012, 02:43 PM   #14 (permalink)
Chapter: Northern
@DailyDriver - thanks for the tips! So to access the screws, you just gently pull down the black plastic trim under the glass that sits toward the front end of the car?
Old 12-24-2012, 03:01 PM   #15 (permalink)
Yes, may I stress the 'gently' part of the removal process. These things are very very fragile and don't take much to break. What I do is take a small pry bar and just push down very evenly until the whole thing starts to come off. Patience is very helpful. So once you get it off, yes you can just push it back into the roof carefully. This exposes screws.
Here are some pictures I figured I would throw up to help anyone who may need the visuals.
This is what you will see when you get the plastic down off of the moonroof glass.
Now this is the back of it and I think it is important to have this displayed here. If you noticed on the metal of the glass where it clips on, there are 3 small indents in the metal. On this fragile plastic, you can see on the back where these clip on to the metal. These are so easy to break too.. so just take it incredibly easy. ((It is slid into the back of the roof in this photo.. it is very UN-sturdy!))
And these are the 3 screws you will see on each side.
No need to completely remove the screws. Loosening them slightly will allow you to properly place your glass if necessary. Be warned.. it may take a few tries and a couple runs on a back road going 65mph to test it for windnoise.
Happy adjusting.
Paul T.
|1999 Taurus SE |
Old 12-24-2012, 03:21 PM   #16 (permalink)
Chapter: Northern
Great! Thank you!
Old 12-24-2012, 05:11 PM   #17 (permalink)
Member Number: 47403
Drives: 2004 SES
Bob R is an unknown quantity at this point
Originally Posted by TaurusDailyDriver View Post
What is so noisy about it?
Everything. Wind noise around the whole car...road noise. If I'm on a rough grain type of asphalt highway, it sounds like I have two Pratt & Whitneys in the back seat. I've tried many brands of tires and not cheap ones either. Can't hear the radio...can hardly hold a conversation. Terrible. If I had the money, I'd get another car, but I don't so I go a little more deaf daily.
Bob R is offline   Reply With Quote
Old 12-24-2012, 06:31 PM   #18 (permalink)
Funny you say that. My car, especially when my Michelin tires were brand new, rides very quietly. The sunroof is making a bit of noise, but that will be fixed and the car will be completely air tight and won't ride loud.
Paul T.
|1999 Taurus SE |
Old 12-25-2012, 10:20 AM   #19 (permalink)
Member Number: 1771
And of course, on the 1st and 2nd gen Taurus, they made that guide out of metal and screws. Cheapo plastic for the replacement. What a joke.
One way to help prevent it breaking is to not slam the moonroof shade back and forth. If you're gentle, it'll last.
Bob, late 03s+ are supposed to be some of the quietest Tauruses ever made. Wonder why you have so much windnoise. Weird.
Sold....
Scrapped...
Old 12-25-2012, 02:23 PM   #20 (permalink)
Drives: 2004 SES
Hi Nick
I got the car used from a dealer with 22K on it in '05 and it was noisy from the the get go. I actually took it back to the dealer and took the service manager for a ride. They had no clue other than try and change the tires. It had Continentals that I scrapped for Michelin Edge tires...no help. I trashed those for the best, "quietest" Toyo's. Worst wearing tire I ever had and still noisy. Tried another tread pattern of Michelins and still the same. Wind noise all over the car...road noise unless I'm on the new style pavement which is better, but not gone. I've gone through 2 sets of struts all around...new front wheel bearings...the works. Nothing cures the noise. Sometimes I wonder if they forgot the insulation. My '88...'96 and '98 Tauruses were quiet as a mouse. I yearn for a quiet car every time I get in this one.
