Location Of 2000 Taurus Starter? - Taurus Car Club of America : Ford Taurus Forum
Old 05-11-2008, 01:20 PM   #1 (permalink)
Member Number: 15647
mwasr has a little shameless behaviour in the past
My car at times will not start, this usually occurs after it has run for a while. I can let it sit overnight or for several hours and then it will start. When I crank the ignition, during the times it won't start, there is no noise coming from the engine at all. The radio and all electrical devices inside work fine, the engine just refuses to start. From what I've read online I believe the problem is the starter. I can't find a schematic of the engine that shows the location of the starter. It's a 2000 Taurus SES with a 3.0 V-6 engine. I have no mechanical knowlegde hardly at all. I figured if I can at least find the part then I could possibly replace it myself. I'm a disabled, single father with limited funds if you know where I'm coming from, can't afford a garage at the moment. Any help will be greatly appreciated. Thanks.
mwasr is offline   Reply With Quote
Old 05-11-2008, 01:39 PM   #2 (permalink)
Member Number: 13090
plato has a little shameless behaviour in the past
in a Vulcan (OHV engine) the starter is right below the oil filter. DOn't know where it is in a Duratec (DOHC)
plato is offline   Reply With Quote
Old 05-11-2008, 01:59 PM   #3 (permalink)
silvapain's Avatar
Member Number: 1808
Drives: 2007 Mazdaspeed 3
silvapain is on a distinguished road
For both it's right at the flexplate, on the radiator side of the engine.
- Daniel
Current:
2007 Mazdaspeed3
Past:
1997 V8 SHO Silver Frost - ELISJOY
1997 V8 SHO Ebony Satin - RIPElaineRIP
1997 Vulcan GL - RIPSuzanneRIP
1990 Vulcan Sable - NONAME
silvapain is offline   Reply With Quote
Old 05-11-2008, 03:04 PM   #4 (permalink)
Member Number: 125
Make sure when you turn the key on you hacve 12v on the small witre going to the starter.
Could be the relay or the TRS.
Old 05-12-2008, 01:33 AM   #5 (permalink)
fdogg96's Avatar
Member Number: 11956
Drives: 1995 Gen 2 yo!
fdogg96 has a little shameless behaviour in the past
You can follow your battery cable...one leads to the alternator and the other one to the starter.
Clubs: TCCA-WEST COAST and SHO-CAL
fdogg96 is offline   Reply With Quote
Old 05-12-2008, 04:24 PM   #6 (permalink)
durasel's Avatar
Member Number: 3580
Drives: 03 SEL Premium DOHC
Trader Score: 29 reviews
durasel has a spectacular aura about
The starter went on my parent's 00 vulcan Taurus with 15,000 miles on it.
4 Taur Family:
98 Comfort DOHC
00 SE
03 SEL Premium DOHC
04 SES Sport DOHC
2003 SEL Premium
durasel is offline   Reply With Quote
