Member Number: 12123
Guys, I have searched all over for a pic of where the crank position sensor is located. I have a Ford service cd but the picture is awful and the instructions are to jack up the car and then replace it. I have a 2002 Sable with the Duratec engine. Does the Chilton or Haynes manual show it better? Much thanks.
Member Number: 13722
Drives: 1996 Ford Taurus G
3.0 OHV "Vulcan"
No longer with us. :(
Rep Power: 7 ![]() |
Well, I'm not 100% sure about the duratec, but I know the vulcan has it externally mounted behind the crank pulley. Perhaps the 'tec has it there too? It wouldn't hurt to check.
Currently driving a 2009 Focus SE Sedan w/5-Speed! Previous cars: 1997 Geo Prizm 1996 Ford Taurus G Formerly "Mr. X" |
Member Number: 8940
Just look for wires hooking up to your engine near the bottom just over the oil pan. It should be just 2 wires hooked up to a connector attached to the engine.
Member Number: 140
![]() The pic shows '99. '02 is similar.
RIP TCCA ![]() '96 ES SHO -'98 Black SHO - '99 Graphite Blue SE - '99 3L SVT Contour Find me at the best Taurus and Sable owners online resource. |
[/quote] Thanks to everyone! I will pick up the part today and try to get it in tomorrow. |
Member Number: 140
It's probably easiest to access the sensor from the side, with the wheel and inner fender liners removed.
Well, got it done. Had to remove the fender well cover as was suggested. I also had to remove another inner cover on the inside of the firewall above the tire (2 screws, no big deal) and a metal bracket that was covering up the sensor bolt. Removed 3 fasteners on side and loosened 2 on bottom and slid it out then it was a piece of cake. The sensor solved the no start problem. My symptoms were intermittent hard starting without any check engine light until it completely refused to start. I did pull a code for cylinder misfires but it did not trigger the light. Thanks for the help and hopefully this thread will clue someone in with their issues when the time comes.
Member Number: 11855
Does anyone have a pic of the sensor location
#9 (permalink) | |
Member Number: 36682
Drives: Sable LS Premium '03
Sable LS '01
Real pain for the bolt. To find it, remove the pas side wheel, pull back the inner fender on the front side of the axle. It is to the rear of the crank pulley, behind a brace. There is a wire support for O2 in the way, remove it. The bolt is 8mm or 5/16, either equal. quarter inch socket, deep wall and rachet will losen the bolt. Getting the bolt out is a hassle as there is not a straight shot around the brace to the bolt, it is at an angle. The sensor just pulls out, has an O-ring to seal it. -chart- |
#10 (permalink) |
Member Number: 3617
Drives: 2000 Taurus SE, 3.0L Duratec
Crankshaft Position Sensor Replacement, 2000 Duratec
Location: Just to the rear of the crankshaft pulley damper, covered by a bracket. . Disconnect negative battery cable. . Place front of vehicle on jack stands. . Remove right front wheel. . Remove fender liner (front half only). . Remove alternator splash shield (two 5.5mm screws). . Remove bottom alternator bolt (13mm) and shield. . Remove bracket covering CKP Sensor, by removing three 13mm side bolts, loosening both 10mm bottom nuts, and sliding the bracket out. . Remove serpentine belt. . Remove top front alternator bolt (18mm) and rotate alternator clockwise enough to remove CKP Sensor. . Remove and replace CKP Sensor (8mm). <>< |
