02 Stalls When Turning On Ac Or Heat - Taurus Car Club of America : Ford Taurus Forum
post #1 of 6 (permalink) Old 03-30-2008, 02:50 PM Thread Starter
Whenever i turn on the ac or heat in my car, it either stalls or tries to stall.As someone suggested on here, I cleaned the idle air control valve, and tested the voltage going to it per the haynes manual. It is reading around 12 to 12.5. Yesterday, I was sitting in a parking lot, and turned the heat on, and it died. It then took me trying several times before it would start again. What is strange is that no matter if I turn on the ac or the heat it does this. It will try to stall out so much so that, the battery light and dash lights come on and the tach needle drops, before it kicks back in again.It will continue to do the "try to stall, kick back in , try to stall, kick back in, until it either stalls or I turn the ac or heat off.
I have a brand new battery, alternator tests fine, the whole ac system is new. I just had the fuel filter and the spark plugs changed,and a bunch of vacuum leaks fixed, which fixed some serious hesitation on acceleration issues I was having. The car does not have the check engine light on. Has anyone ever experienced this? Or have any clues?
stevensmommy is offline
post #2 of 6 (permalink) Old 03-30-2008, 03:17 PM
Maybe the AC compressor is going bad. Either that or the IAC is bad.
post #3 of 6 (permalink) Old 03-30-2008, 03:46 PM Thread Starter
The Whole ac system is new, including the compressor. It also happens when I turn on the heat.
post #4 of 6 (permalink) Old 03-30-2008, 03:51 PM
Don't Be Stupid
<div class='quotemain'>
The Whole ac system is new, including the compressor. It also happens when I turn on the heat. [/b][/quote]
The compressor will be on in every position but vent (just to the left of off). Maybe they didn't oil the compressor right when it was installed.
00tec-satx is offline
post #5 of 6 (permalink) Old 03-30-2008, 05:07 PM
Try turning the throttle stop screw in a 1/4 turn once contact is made with the stop. Or get a new IAC.
Have you disconnected the battery and let the car relearn idle?
post #6 of 6 (permalink) Old 03-30-2008, 07:36 PM Thread Starter
No I need to do that.
